It is currently Mon Jun 08, 2026 9:55 am
 Post subject: distributor problem
PostPosted: Thu May 18, 2006 2:12 pm
over the weekend i was changing the points in the luv. When i pop the cap and rotor of i noticed that a wire in side the distributor was broken it was not the primery wire but what i belive is the lead wire. it looks like it is sodered to the side of the distributor. My question is would that be a reason for the truck to run rough and what size wire is it and can it just be spliced into
easyhour
of course it hurts you are being screwed by an elephant
PostPosted: Thu May 18, 2006 5:12 pm
if it was soldered onto the side of the dist. I would think it's just a ground....so one end looked like it was soldered where'd the other end go?
Resident lurker
PostPosted: Thu May 18, 2006 7:00 pm
that end has an eylet on it and with a screw that is screwed into the bottom plate inside of the distributor
