It is currently Mon Jun 08, 2026 3:22 am
 Post subject: randome discovery...
PostPosted: Wed Nov 02, 2005 11:37 pm
So i was browsing through my LUV shop manual and found something cool. Now i had always wondered how you drain and refill the front diff fluid. I figured since it has manual lock hubs that its not a big deal to run diff fluid for a couple hundred thousand miles as youu probly only use the front axle a few hundred miles in that period. Well i found out there the vary bottom bolt that hold the third member in actuall goes into the case and creats a passage for fluid, AKA a drain bolt! I dont know why i never looked for this, but if i hadnt i figured someone on this site might not know this either.
PostPosted: Thu Nov 03, 2005 10:19 am
I sure wish our DANA 60's at work had that option. we have to pull the housing plate and reseal them! fortunately on the transmissions I weld in a drain plug to make them easier to service. It takes a long time to get rewarded though we have 500+ vehicles and 7 people to service them each month! plus another 23 people to do repairs.
Government... if you think the problems we create are bad just wait till you see our solutions
Users browsing this forum: Bing [Bot] and 48 guests
