It is currently Sun Jun 07, 2026 11:55 pm
 Post subject: Rusty cab vents
PostPosted: Sat Sep 21, 2002 10:22 am
Does anyone know of a good way to remove the rust from inside the cab vents (the pillar vents) They are the vents just aft and above the door handles. I'd like to remove the rust before it gets too bad. Any suggestions?
 Post subject: cuttin
PostPosted: Sat Sep 21, 2002 7:20 pm
i cut mine out- patched the hole with some galv. steel - a little fibergalss work and it looks like nothing ever belonged there. thats my solution. :twisted:
Brent
PostPosted: Mon Sep 23, 2002 5:21 am
is sand blasting an option?
03Cobra
PostPosted: Mon Sep 23, 2002 9:44 am
Im not sure if the metal is thick enough to handle sandblasting without distorting plus trying to work thru 3 little louvers is a problem, i dont think there's a nozzle small enough to work in such an intricate area
PostPosted: Mon Sep 23, 2002 4:28 pm
I sandblasted mine. Just stuck the nozzle in between the vents and moved it around in circles. It wasn't perfect but it did a pretty good job.
If at first you don't succeed, try it like your wife told you to do it.
PostPosted: Mon Sep 23, 2002 4:30 pm
have you tried sand paper wraped around the end of a small dow rod?
might do the trick be tedious as hell tho.
just tossing out ideas here
IMO i wouldnt fill them unless they were totaly unrepairable, i think its one of the most noticable things about the luv
PostPosted: Mon Sep 23, 2002 6:30 pm
Yep!! Plus it is a really good spot to hide your door release buttons when you shave the handles. Not like I am going to do that or anything! :roll:
PostPosted: Tue May 03, 2005 8:26 pm
It is a good thing that I decided to look back through the post because I was wondering how I was going to get rid of the rust inside my vents but now I know how. Thanks 8)
1983 Suzuki Gs550 Sportsman
1986 Full size Chevy P/U
1993 Volvo 850 GTL
