It is currently Sun Jun 07, 2026 9:36 pm
 Post subject: what the hell is????
PostPosted: Sat Mar 12, 2005 7:15 pm
what is the little black box built into the side of the bed in my 1977 luv ? anyone know? also what are the #'s on the side of the block? are they supposed to be there? i think mine says somethingt like b200?????
PostPosted: Sat Mar 12, 2005 11:29 pm
evaporative charcole canister. It catches fuel vapors and releases them into the carb under vacume.
PostPosted: Sat Mar 12, 2005 11:32 pm
how does it work i don't under stand it's point
can it be removed
if so
how
PostPosted: Sun Mar 13, 2005 12:38 am
The evaporator is in the bed?
PostPosted: Sun Mar 13, 2005 10:27 am
If you look on your fire wall on the right side, you'll see a little junction of black hoses. 1 goes to the oil pan,1 goes to the carb or manifold ( I can't remember now), and 1 goes to the black canister in the bed. That canister also has a couple lines going to the fuel tank. I don't know exactly how it works but it makes the fuel tank, and oil pan vent back into the engine combustion chamber to be burned rather than letting the fumes out into the environment.
How'd I do??? :D :roll:
PostPosted: Sun Mar 13, 2005 1:03 pm
That expansion chamber thing in the bed is to capture fuel fumes from the tank and make sure they don't get out as pollution. It also reclaims whatever condenses back to liquid back to the tank, so it has a useful purpose besides the environmental aspect. Rondog has it pretty much explained, no fumes get out to kill Condors or Whales and stuff.
The numbers on the side of the block (driver's side) will be G200 or G180. G180 is a stock LUV motor, 1.8L. A G200 is a 1.9L that is a little bit bigger, therefore a little more power. It would come out of something newer like an Isuzu pickup, trooper, car or some early Chev S10s. Apparently your truck has had the motor swapped at some point.
PostPosted: Tue Mar 15, 2005 1:42 pm
All of my newer trucks that I have had have this but my 84 pup (81 luv) doesn't. I have the bed off and put a fuel cell in place of the tank and never removed a charcole canaster in the vent system. Interesting?!
I TOOK UR MOM DRAGGIN LAST NIGHT
Bagged 84 Pup
Bagged 53 F100
stock 72 Citroen DS19
PostPosted: Wed Mar 16, 2005 12:20 pm
can i bypass it with like a splitter for like a vaccume hose because i took of the bed and i don't want to drill new holesso can i by pass it
