It is currently Sun Jun 07, 2026 11:54 pm
 Post subject: timing
PostPosted: Tue Jan 04, 2005 7:01 pm
how do you set the timming properly when putting the chain back on?
 Post subject: Noyz
PostPosted: Tue Jan 04, 2005 7:14 pm
Have you both the chain cover on the front of the block and chain off?
PostPosted: Tue Jan 04, 2005 7:18 pm
no the cover is still on
 Post subject: Noyz
PostPosted: Wed Jan 05, 2005 10:12 pm
You can't put the chain back on correctly without the cover off. Becuz of the chain tensioner, there's more links on one side than the other. Even if you dangle the chain down there, get it on the crank sprocket, and get it tight over the cam sprocket on the side opposite the tensioner, you can't tell if the crank and cam are in sync. Not for sure. You want the directions for doing it with the cover off?
PostPosted: Sat Jan 08, 2005 9:38 am
its alrite, doesnt matter ive solved my problem, wasnt the cam after all. turned out to be the firing order :oops: i was 90 degrees out
 Post subject: Noyz
PostPosted: Sat Jan 08, 2005 2:44 pm
I take it you got the plug wires in wrong. That's easier to fix than the chain would've been.
PostPosted: Sun Jan 09, 2005 6:36 pm
yeah, i had to rotate all the plugs one spot clockwise
