It is currently Sun Jun 07, 2026 9:37 am
 Post subject: torque specs
PostPosted: Mon Jun 07, 2004 4:51 pm
im ready to begin rebuilding my stock 1.8, but dont know the torque specs for anything. does anything know them for the internals? thanks
PostPosted: Mon Jun 07, 2004 5:53 pm
A haynes manual will be your best friend. At the moment i dont have mine though. Some of the other guys on here will be able to help though.
PostPosted: Mon Jun 07, 2004 6:32 pm
what specs are you after i might be able to help out
PostPosted: Wed Jun 09, 2004 10:00 am
i need torque specs for the mains, connecting rods, and for the head. also, need to know how to time it, thanks.
PostPosted: Wed Jun 09, 2004 11:34 am
Here is what I remember.
Exhaust Valve Adjustment is .254
Intake Valve Adustment is .010
Header Torque is around 88ftlbs.
PostPosted: Wed Jun 09, 2004 11:53 am
If you are diving into a motor rebuild then at least a Haynes or Chilton manual would be almost a requirement. Compared to the costs of parts for the motor the $15 or so the repair manual costs is money well spent. Check local auto parts stores for them.
Even better would be a factory repair manual. They come up fairly regular on eBay and I think I've seen a couple places online that deal in used/old stock factory manuals as well. Search ebay for "chevy luv manual" and you should come up with a few hits.
PostPosted: Wed Jun 09, 2004 1:26 pm
800XL, do you have the VAC diagrams with your service manual? I need them for a 76, but also need them for an 80.
PostPosted: Wed Jun 09, 2004 11:03 pm
ill have a look later tonite for the specs on the mains n con rods
PostPosted: Thu Jun 10, 2004 1:24 am
i'll keep you in my mind.
i just ordered a factory manual off ebay for the exact same reason. should be getting it in the mail anyday now 8)
PostPosted: Thu Jun 10, 2004 3:33 am
Luvtruck.com Wookie
the torque spec for the head bolts on a g180 are 72 flbs
TiLtEd wrote:
Boobies!!! :D
PostPosted: Fri Jun 11, 2004 10:37 am
yeah i know i need to get a shop manual, i have one but its for a '72, and the engine isnt the same as my '80. can anyone help me with torque specs for mains and connecting rod, im really tryin to get my engine together fast so i can get my LUV back on the road, :)
btw, thanks wheres the luv at? for the head torqe specs
PostPosted: Fri Jun 11, 2004 11:49 am
.254 clearance for the exhaust? Is that right? Thats more than 1/4" clearance! I thought the clearances were like .008/ intake and .010 for the exhaust.
PostPosted: Fri Jun 11, 2004 2:18 pm
From the Haynes manual:
(In ft/lbs)
Main bearing cap bolts: 72
Connecting Rod bearing cap bolts: 33
From the factory 79 manual:
Connecting Rod bearing cap bolts: 43
Dunno which is right on those con rod caps, Clymer and Haynes agree at 33, but the 43 the factory manual shows is about the same as the 44ish shown in my factory 86 Trooper book for the 2.3L motor. I know its not the same motor, but I thought I'd just acknowledge the fact that the numbers agree on the two motors. (Which are similar)
On the head torque, Haynes and the factory book show initial of 61, final of 72. Best to torque them in stages.
For valves I have .006 for intake and .010 for exhaust measured between the valve stem and the rocker arm (not rocker/cam as Haynes manual states, factory manual shows same numbers but says the right place to check). This is the low temp reading so do it cold and I have not seen a number for doing it warmed up.
The factory 79 manual does have several diagrams of vac hose routing, but they are broken up into sections for different systems. They don't have the overall diagram you find on the hood if it hasn't been painted over or sanded off. At least, I have not found it yet.
PostPosted: Fri Jun 11, 2004 8:27 pm
awsome!, thanks 800, i can now start putting the engine together tom night :lol: , after 6 months of it sitting in the engine shop, it may be on road soon again!!!!! thanks again guys,
PostPosted: Sat Jun 12, 2004 9:19 pm
Sure is. I thought it was too big. Not a 1/4" but MM.
I might have got the numbers transposed though.
