It is currently Sun Jun 07, 2026 12:30 pm
 Post subject: weber and offenhauser
PostPosted: Fri Apr 16, 2004 10:06 pm
just got the setup and now dont know what to do with it. I have no idea how to hook this damn thing up. I know how to take manifold off and put new one one but there is two gas lines going to the stock carb and only one going to the weber. Also, where the hell do you connect the vac advance hose to on the offy? If i can figure out those 2 things i think im good...also i noticed there is a spacer about 1 1/2 inches between the offy and weber...strange...anybody have this/know what it is and for?
PostPosted: Fri Apr 16, 2004 11:21 pm
Put a "Y" fitting to a short piece hose and connect to the carb. Then connect the two fuel lines from the truck to the other two connectors of the "Y" fitting. Is there no vacuum connector on the Offy manifold? Maybe drill and tap one in before mounting. Seems my Weber came with one vacuum port. Too late now to check. The spacer on my setup aligns studs for mounting, cuz the four studs on the manifold don't line up with the four mount holes on the carb.
PostPosted: Sat Apr 17, 2004 4:21 am
are you the one that won the offy off ebay ? it said in the auction it didn't have one. like robert.. said just drill and tap one in..
PostPosted: Sat Apr 17, 2004 12:49 pm
no didnt win it off ebay, bought it out of the classifiads on this site weber/offy both used for 300 bucks.
PostPosted: Sat Apr 17, 2004 1:25 pm
Nate:
My Weber has 2 vacuum ports underneath the round black choke thermostat cover. 2 different sizes. My spark advance is connected to one and the other is capped.
PostPosted: Sat Apr 17, 2004 2:14 pm
When I was running a weber I found an inline fuel filter with a return port on it to handle the fuel line issue. It looked basically like the stock luv fuel filter only smaller and with a thing coming out the side where I hooked the smaller fuel return line. It worked very well for me. I figured I'd be getting the benefit filtering any crap that made it past the main filter before it got passed back to the tank for another run.
PostPosted: Sun Apr 18, 2004 1:57 am
got the weber/offy in tonight finally. Tuned the carb good....drove it...wooohoooooo...Whats the big woop? Instead of spinning one tire i got both to barely chirp. Hardly a difference.
PostPosted: Sun Apr 18, 2004 4:42 pm
Well pull it back off and I'll send you a stock setup, then you can send me the offy and weber. Sounds like a good trade to me! :lol: 8) :lol:
Resident lurker
PostPosted: Sun Apr 18, 2004 5:01 pm
What the Offy and Weber come off of? Maybe too small jets? The Weber I have on a stock intake on my LUV will chirp tires even in cold weather.
PostPosted: Mon Apr 19, 2004 1:34 am
riiiight...well too bad for you diarmadhim that im not that stupid...i figured out there was something holding the thing from opening up the secondary and boy when i got that out of the way it freakin rox. My truck sounds like its got a beast of a motor in it when i romp on it. It chirps the tires but doesnt squeal them...kinda bummed bout that...
PostPosted: Mon Apr 19, 2004 8:31 am
What?? :lol:
Glad to hear you found the problem.
Resident lurker
PostPosted: Wed Apr 21, 2004 1:33 am
so i wanna get my weber tuned just perfect, how do i do it? Should i use a vacuum gauge to do it? If so, how? If not, how?
PostPosted: Wed Apr 21, 2004 10:04 am
Since you didn't get any paper work with your Weber and I did with mine, I can scan the pertinent portions of it and email it to you. You want? Unless it's on their website. Lemme know.
PostPosted: Wed Apr 21, 2004 1:02 pm
that would be excellent...email or here...email is nathan_007@softhome.net
PostPosted: Thu Apr 22, 2004 11:01 pm
Weber tuning info can be found at http://www.carbs.net/Weber/adjust.htm
In my experience, follow those instructions and it will be good to go.
