It is currently Sun Jun 07, 2026 6:49 am
 Post subject: Emissions question
PostPosted: Mon Jan 26, 2004 3:30 pm
I still have all my emissions hooked up but there is a sound coming from the back of the pump it sounds like alot of air being sucked into the back of it, its a little hole and when I plug it the truck runs better. Does anybody elses smog pump do this or has my pump gone out. Also isnt the carb choke suppose to open fully when the truck warms up because mine always stays shut or closed and if I try to open it the truck just shuts down. Thanks Shane
By the way I got my truck to run but it still idles wierd. It idles up and then down it still has problems and it doesnt overheat anymore, I guess it was the water pump after all. Thanks Guys
PostPosted: Tue Jan 27, 2004 5:10 pm
Can somebody help me on this, I need to know if I need to buy a new pump or not. Thanks, Shane
PostPosted: Tue Jan 27, 2004 11:20 pm
is it the pump itself, or the valve behind the pump, if its the valve, it could be leaking vacuum from the engine, which would explain why your engine would run better when you plug it. if its not that valve, there is a vent on top of the pump that it could be coming from, if not then the pump could be bad, you can find them easily in junkyards, i got mine from an isuzu p'up with a 1.9. it was identical to the one from my luv. but it really sounds like the valve is bad, you can also get them from junkyards. as far as the choke goes mine choke takes awhile to open, like 10 minutes idleing.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
PostPosted: Wed Jan 28, 2004 1:10 am
its not the check valve that is on the air manifold and its not that vent on the top, its coming from the back of the pump there is a little hole on the back so does that mean its bad. The choke doesnt open up at all even after 10 min. of idling. Thanks Shane
PostPosted: Wed Jan 28, 2004 1:42 pm
What happens when you shove a screw into the hole? I will have to look at the one at the house to give you more info on it.
PostPosted: Wed Jan 28, 2004 9:26 pm
i checked and my air pump and i see the hole you are talking about but since my air pump is off my luv i don't know if air comes out. i'm gonna be putting it back on in a couple of days since i gotta get it inspected. so i'll let you know what i find out.
 Post subject: Re: Emissions question
PostPosted: Wed Jan 28, 2004 11:23 pm
MIne stock motor did that for awhile. I adjusted the timing and it seemed to help some.
PostPosted: Thu Jan 29, 2004 12:06 am
I need all the help I can get thanks 81luv4x4. And Zane I did adjust the timing after I got it to run and idle right. Thanks guys
PostPosted: Thu Jan 29, 2004 7:23 am
So are you good now?
Users browsing this forum: No registered users and 59 guests
