It is currently Sun Jun 07, 2026 2:33 am
PostPosted: Tue Mar 04, 2014 9:26 pm
hey all,
I have a '79 stock Luv. I broke the bleeder screw off in the front caliper. I managed to get the broken screw out of the hole. I am having a tough time figuring out what size to replace it with. Anyone know the right size? Summit Racing suggested the Dorman - Help Bleeder Screws 3/8-24 x 1-1/4 Inch but they were too thick... Thanks!
PostPosted: Wed Mar 05, 2014 12:38 am
Brake line fittings are M10x1.00, the brake bleeder may be a slightly larger, if so it may be a M12x1.25. Since you will have to bleed the system anyway now that one side is open remove the other front side bleeder, take it to the parts store for a match. If you have a metric tap & die set they often have a thread pitch gauge, you won't likely have a die with fine enough threads but at least you could use one to determine the diameter.
PostPosted: Wed Mar 05, 2014 3:29 pm
since you have to bleed and if worst comes to worst a new set of calipers is under 100.00.just a thought
http://www.autozone.com/autozone/parts/ ... 57ylZ8knro
PostPosted: Wed Mar 05, 2014 7:42 pm
Thanks you guys! I appreciate the tips. I do have a tap and die set, I hadn't thought of it. I believe that will work to figure out the specs.
Users browsing this forum: Baidu [Spider] and 32 guests
