Replaced fuel pump relay with a Nissan 5-point relay out of the Z parts car. Works beautifully. Drove truck around the block a few times. No issues.
Everything on drivers side of the engine bay for wiring has been looked over and patched and covered in the generic black plastic coverings. Everything for starting and ignition and fuel now work flawlessly.
Removed the hacked up wiring for the alternator/voltage regulator and re-wired it with new wiring. Used the heat shrink type crimp connectors. I hate using crimp connectors honestly, but better than twisting and taping wires. Also, soldering iron seems to have grown legs and disappeared
File comment: New wiring for alternator/voltage regulator.
I figured I would have fun with it while I was going through the harness. All ignition wiring is labeled with blue, lighting is labeled with yellow (as was stock wiring?), and voltage regulator/alternator labeled with white, taped to hold it together underneath the coverings, and to aide in wiring identification if I ever have to go back through.
Removed the voltage regulator wires from the stock fuse box and ran them to a new 6 slot ATC fuse common hot feed panel. When running GEN light is no longer on constantly, and FASTEN SEAT BELTS light turns on with the key and turns off about 30 seconds after. Then turns on for another 30 seconds after engine starts, then shuts off again. (Normal?)
...and still no voltage regulator issues. Battery is charging normally with 13.9-14.1 volts.
One thing I've still noticed is that the HEAT light will light up and flicker for a moment before turning off when the truck is first started. Is this normal ??
File comment: Finished wiring for alternator/voltage regulator, and what remains to be done...
And (above) is what remains, the mess of wires there by the fuse box will be sorted out and fixed up (thats the other area of hacked up wiring, still working on fixing it.) Perhaps the flickering HEAT light will disappear once I finish up with the harness?
Also, the black coverings you see are what I am using to cover the entire harness. All the wiring on the opposite side of the engine bay has been repaired and covered. (Will get pic in daylight tomorrow.) All that remains is the hacking that was done by the fuse box, and installation of second 6-slot ATC fuse panel for remaining electrical items.
