It is currently Sun Jun 07, 2026 7:21 pm
 Post subject: manifold question
PostPosted: Thu Aug 25, 2011 9:02 pm
we put a new exhaust gasket on, before we did so the surface was scraped clean, but it is still leaking air. there is a bolt that just keeps turning, is there any kind of gasket sealant or metal tape? we can use that will hold up to the high heat? ( i apologize in advance if it sounds like a dumb question- been in the sun too long too many days in a row :smt117
What part is this?
What is it for?
How Do I test it?
Where do i get a new one?
Are we there yet??
 Post subject: Re: manifold question
PostPosted: Thu Aug 25, 2011 9:46 pm
You are going to have to pull the manifold and helicoil the bad threads. There is also a chance the manifold is warped. There is no sealant or tape to fix a leak like that.
PostPosted: Thu Aug 25, 2011 10:24 pm
Most likely, your manifold is warped, any machine shop in your area should be able to re-surface it for you. Shouldn't be more than $20.
PostPosted: Thu Aug 25, 2011 11:44 pm
thank you we will look into in our area. were kinda remote but will look into it.
i also am supposed to ask if on the intake manifold we can use 1form.a.gasket sealant in a tube by permatex brand and is there any advice anyone can offer while we have it off?
this truck has become a nightmare.
its became every gasket and hose and belt ect in it is needing replaced :smt010 :smt017
What part is this?
What is it for?
How Do I test it?
Are we there yet??
PostPosted: Fri Aug 26, 2011 1:05 am
Honestly, you shouldn't use anything as a gasket other than a gasket made for the application. The intake gasket and exhaust gasket are not that much. Check around, it is better to do it right the first time than to have to do it half a$$Ed several times, please don't take offense to that..., we have all done stuff half a$$Ed and had to revisit the issue later on~ best to do it correctly the first time so you don't have to worry about it or second guess your work. As far as the intake manifold being warped, not saying it can't happen, but if your intake is warped..., you have bigger fish to fry. If you got your intake hot enough to warp, I wouldn't be supprised if a cylinder or two werent damaged, let alone the head itself~
Just my opinion~
PostPosted: Fri Aug 26, 2011 1:10 am
Also~ Gasket Sealer/Maker is intended to be used with a gasket, you put a lil dab of sealer/maker on you index finger and thumb and pass the paper gasket thru you fingers, applying a thin layer on each side. This will ensure a leak proof seal on any paper gasket. For Cork and Rubber gaskets, you want to do the same thing but instead of gasket maker/sealer, you would use engine oil (preferably new oil). This will allow the cork gasket to slide/shift into place evenly as you tighten it down.
PostPosted: Fri Aug 26, 2011 6:34 am
Jedi Pimp Master
OK I think things kind of ran away from your original question so let's go back there. Bolt won't tighten. First take the bolt to the part store and ask for a helacoil or Keensert in the correct size. Drill the hole out to the correct size(either should come with a drill bit) run a tap in the hole to cut threads keep it wet with light oil better to go in and out several time a little deeper each time. Use the included tool to install the thread insert. Examine the remaining holes to see if they need repair. NOW you have solved problem #1 now you can look at whether or not the manifold might be warped. Lastly remember this is a 30 year old truck it's always going to have little problems, because bearings seals hose are 30 years old also.
Good luck
SRAD
My Wife is faster than you think you are
PostPosted: Fri Aug 26, 2011 9:48 am
Good luck
SRAD
PostPosted: Fri Aug 26, 2011 10:35 am
Thank you for all the answers.
we cant help but remember its 30 years old lol every thing touched either looks as if its going to crumble or IS :microwave:
What part is this?
What is it for?
How Do I test it?
Are we there yet??
PostPosted: Fri Aug 26, 2011 3:00 pm
Jedi Pimp Master
Indeed it is sir. Just added a little detail
to your post in case they were not aware
Of the process. Allow me to apologize
SRAD
