It is currently Sun Jun 07, 2026 10:31 pm
PostPosted: Sun Jun 12, 2011 9:50 pm
ive git my luv out of storage again,because i spotted a 78 passed by in front the house, and courous about these 1.8 engines,
PostPosted: Sun Jun 12, 2011 10:36 pm
Not sure if there's a common problem with the 1.8's. They're original to the truck, so that makes them somewhat desirable to the owners who want to keep them original. I read that the Hitachi carburetor is ususally switched out to a Weber because the Hitachi is, well...old. ( I did it) My '79 has had issues with the fuse box; the brass holders corrode and cause all sorts of problems which are easly solved by cleaning them. The old gas tanks get muck built up and cause gas feed problems, and the gas lines themselves get soft and can collapse under suction created by the fuel pump. Being "old" mine has several phantom issues that are narrowly related to fuel supply.
PostPosted: Sun Jun 12, 2011 10:41 pm
I would say carbeuration and overheating that usually results in blown head gaskets...
PostPosted: Mon Jun 13, 2011 1:08 am
vacuum lines cracking seems quite common as well thell run horred with a big vac leak.
but yes over heating is a big killer
are we taking early 70s 1.8 or late 70s 1.8 :?: cant remember if the early ones had different issues.
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
PostPosted: Mon Jun 13, 2011 5:29 pm
i just had my top end rebuilt, truck still runs hot new water pump and weber carb. tuned perfect it still runs hot though, is there anything that im missing? this thing should run perfect
1977 LUV weber 32/36 dgv soon to be boosted
PostPosted: Mon Jun 13, 2011 6:03 pm
Make sure the Radiator is good and it does have a thermostat, right? Fan and shroud are good?
PostPosted: Mon Jun 13, 2011 6:45 pm
I've always heard that the head gaskets are quick to go on the back side of the engine (the LUV I bought was bad there and so was about 3 other LUVs I've seen).
PostPosted: Mon Jun 13, 2011 10:45 pm
The overheating can be remedied by changing out the thermostat with a balanced 160 deg thermostat that is available in the Mr. Gasket line at any local O'reilly store. I can't remember the part number but I can get it for you if you like.
PostPosted: Sun Jun 19, 2011 2:44 pm
I have ran it without one and with a couple of new ones in the past couple of months, if it can be solved by just a different temperature thermostat that would suprise me, the radiator has been flushed twice and seems as if it is working properly, no leaks at least.
PostPosted: Sun Jun 19, 2011 9:21 pm
Flushing a radiator dose not always clean it fully they need to be taken out and roded out to clean the tubes completely.
PostPosted: Sun Jun 19, 2011 9:28 pm
The most common problem I have with my LUVs is the gas tank is always empty. :evil: :P
PostPosted: Mon Jun 20, 2011 8:52 am
The most common problem with the stock g180's appears to be a distinct lack of basic mechanical skills...
PostPosted: Mon Jun 20, 2011 10:37 am
:signiagree
PostPosted: Mon Jun 20, 2011 11:06 am
It's just a 4 cyl, ANYONE can work on it :roll:
PostPosted: Mon Jun 20, 2011 11:14 am
A good flowing water pump t state and a high cfm electric fan should keep it cool
Chevy luv with a redneck grabber green paint job lol...
these are links to my luvs pics.
http://s922.photobucket.com/albums/ad68 ... v%20truck/
viewtopic.php?f=33&t=22598
:usa :minigun: :bio:
PostPosted: Mon Jun 20, 2011 3:43 pm
i took it out completely and flushed it with a water hose until it was totally clean, there is also a kink in the back of the intake manifold where the heater core was by passed i dont know if that would have anything to do with it, i also have an electric fan off of a ford taurus that i was thinking about using
PostPosted: Wed Jun 22, 2011 12:34 am
The biggest problem I've seen in all the years that I've been involved with all of the the Luvs I've owned and all the years I've been on this site...is it seems to me like some people don't understand what the hell "RTFM" stands for. Or why we all have two eyes, two ears, but only one mouth....and all of that is supposed to be managed and controlled by a brain. Plus all of that should be utilized to it's fullest potential before we use any tools with our own two hands.
Then people start using terms like "POS" and "FUBAR" to describe their truck and terms like "PITA" to describe them. And pretty soon...they just fade away.
And the rest of the people here that aren't too cheap to invest a few bucks in a decent manual, aren't too lazy to use the search button here, and are willing to utilize fully the advice given by those of us here that have labored over these great little trucks successfully for a lot of years...well they all just seem to continue to grow and prosper. And their trucks keep running strong.
Myself personally...I am grateful as hell for what I've been given by this site, Ben and his hardworking staff, and it's members. I have rarely ever logged in here and nosed around without learning something new. I only hope I've given enough back that was worthwhile.
So if you wanna know what I think is the biggest problem with these trucks...IMHO it would be the truck's owner.
PostPosted: Tue Jun 28, 2011 7:45 am
:signiagree
