It is currently Sun Jun 07, 2026 10:31 pm
PostPosted: Wed Jun 15, 2011 12:34 am
I have to crank over and pump the gas a bunch to get it to start in the mornings but when warm will start just fine. What could this be? I thought at first it was the weber carb set up. But it seems like i am getting enough fuel. when it will turn over its really rough I give it gas and it will back fire in the intake through the carb and die so i crank it again and let it sit until its warmed up. any suggestions?
1974 Chevy LUV 4x4 Weberfied
PostPosted: Wed Jun 15, 2011 6:23 am
Back fire through the carb could be a timing problem.
PostPosted: Thu Jun 16, 2011 12:14 am
hmm i think i have her pretty well dialed in any more btdc and she wont go up hills. Think my new points may have burned up better get some new points and a condenser and see if it helps. I just remembered that before i had the weber that it did this until i changed the points
PostPosted: Fri Jun 17, 2011 7:59 pm
whats really funny is the other morning it was real cold out and she started fine hahaha
PostPosted: Tue Jun 21, 2011 8:25 pm
Check the choke set up and also the idle mixture setup too!
