It is currently Mon Jun 08, 2026 2:14 am
 Post subject: Over heating?
PostPosted: Sat May 21, 2011 7:57 pm
I had to drive 20 miles down the highway and noticed that my temp gauge was up 3/4 of the way.
I have replaced the thermostat and water pump, but it still is elevating past the 1/4 normal mark on the stock temperature gauge.
I replaced the radiator cap with one that has a temperature gauge.
Here are the readings from the cap-gauge compared to the in-dash dash. After letting it idle for some time in my driveways it seems to be topping out at 200. Is 200 running to hot or is my stock temperature sensor giving a false reading?
170
190
200
 Post subject: Re: Over heating?
PostPosted: Sat May 21, 2011 8:00 pm
Here are my plugs no leaks and the coolant is clean.
PostPosted: Sat May 21, 2011 9:08 pm
To me it looks like it's pointing at 160, 180, and 190. If you have a 180 thermostat in there, I'd say 190 isn't too far off.
PostPosted: Sat May 21, 2011 10:03 pm
I agree. If you want the stock gauge to read lower when at 180, maybe change the sending unit.
I have two trucks that both barely get off the cold mark. I plan to try changing the sending units to see if it that fixes it.
PostPosted: Sat May 21, 2011 10:07 pm
What temp should I start being worried at?
PostPosted: Sat May 21, 2011 10:21 pm
@ Ben, Oh you are right!
PostPosted: Sun May 22, 2011 9:06 am
Under normal driving conditions I would worry @ 200 or more.
I would be watching very closely at 200, and shut it down up around 210-220.
PostPosted: Mon May 23, 2011 12:11 pm
I would have the radiator boiled out. Try this- get it up to full temp, turn it off, then put your hand on the radiator, starting at the top. My guess is that the bottom part will be noticably cooler than the top, the bottom rad hose could even be cooler than the top. Any of these conditions is a symptom of a partially clogged radiator.
