It is currently Sun Jun 07, 2026 7:22 pm
 Post subject: MSD PERTRONIX installl
PostPosted: Mon Jan 24, 2011 7:10 pm
Just wanted to see if anyone had done the MSD 6A box and Pertronix combo. I finally broke down and tackled this project. Question if you did do this combo did you use any of the negatives on the coil itself? I removed everything from inside of coil and only use wires from the pertonix straight to the MSD box and the thing runs fine. Am I going to f something up by not utilizing the negatives on the coil.
Just wondering! So long points though!!!!
OX
PostPosted: Tue Jan 25, 2011 3:05 am
You can Google the MSD 6A model number and get a downloadable installation sheet with all of the installs from points to mag pickups. Thats what I did.
1979 Luv 2wd, rebuilt impulse G200, Weber 32/36, Offy intake, Delta cam, Pacesetter header, Flowmaster, 2 1/4 inch pipe, lowered 4 inches, Bed shortened 10 inches, 1997 Tahoe wheels with 225/50R16 Toyo Proxes.
PostPosted: Tue Jan 25, 2011 9:58 pm
I did that exactly the way it said but can i eliminate the ground on dizzy itself? It runs with out it but will i jack it up not having that ground hooked up? Im thinking if the MSD box is grounded and its grounded through the pertronix then it should be good?
