It is currently Sun Jun 07, 2026 10:31 pm
 Post subject: Different Heads?
PostPosted: Tue Dec 15, 2009 12:10 pm
I had recently had a blown headgasket on my 180 and I had an extra head from a 200. I was curious if the displacement is in the head or block and does the head make a difference? I own a 79 LUV. Thanks :)
 Post subject: Re: Different Heads?
PostPosted: Tue Dec 15, 2009 12:39 pm
The head has nothing to do with the displacement but is very important to compression ratio. Could also have different valves and clearance with the pistons.
PostPosted: Tue Dec 15, 2009 1:08 pm
if you use the 200 head, you lose compression since the combustion chamber is enlarged, and you dont have as much stroke to compensate.
PostPosted: Tue Dec 15, 2009 1:28 pm
It shoots excess fuel out of the carb and doesn't start anymore. It started once and it was very loud.
PostPosted: Tue Dec 15, 2009 1:34 pm
thats weird. i've never heard of that happening when increasing the cyl displacement. are you running the stock carb?
PostPosted: Tue Dec 15, 2009 2:16 pm
yes, but I think that is also part of the problem. Part of the carb isn't getting power from the speed sensor and therefor won't idle. It had this problem before the head problem but I can't troubleshoot the carb without a working engine.
