It is currently Mon Jun 08, 2026 5:36 am
 Post subject: why would
PostPosted: Fri Feb 20, 2009 9:54 pm
my blinkers still work if my ignition is off and the key is out?
P.S. it did it with the old ignition and the new one i just bought
A good friend will bail you out of jail, and even better friend would be sitting in the cell with you saying how awesome that was!!!
 Post subject: Re: why would
PostPosted: Fri Feb 20, 2009 9:56 pm
Not sure what year you have but my '72 does it as well. Simplicity is the answer. Less circuitry to have everything fused and just assume you'll turn it off to not waste the battery.
PostPosted: Fri Feb 20, 2009 9:58 pm
so as long as they are not running when the engine is off it will close the circut and not drain my battery?
PostPosted: Fri Feb 20, 2009 10:11 pm
All 3 of my LUVs are that way. And if the light is not burning, no juice is being used.
PostPosted: Fri Feb 20, 2009 10:57 pm
Thanks for all the help
PostPosted: Sun Mar 08, 2009 12:19 pm
honestly I thought all vehicles did this just because I've only owned luvs. But I think part of it is because the blinkers are obviously tied in with the hazard lights, which are required to be able to function without the key, because of breaking down on the side of the road and such. Basically, it does boil down to simplicity
