It is currently Mon Jun 08, 2026 10:29 am
 Post subject: Weber & Ethanol
PostPosted: Sat Jan 24, 2009 12:27 pm
Hey has anybody else had a problem with high idle due to ethanol in the gasoline. I have a Weber that is about a year old. Lately it idles about 200 rpms too high. I have the idle adjust screw backed all the way off. I am sure the float is sticking. I was told by a friend that ethanol gels up in the carb and causes havoc. Is this true? I've used Sta-Bil fuel stabilizer in 4 tanks of fuel so far. Any suggestions?
 Post subject: Re: Weber & Ethanol
PostPosted: Sat Jan 24, 2009 12:40 pm
mine would do that , and sometime go up or down a little... vacuum leak...redid the intake gaskets and carb gaskets with a seal called
"the right stuff" been perfect ever since. $16 at autozone
PostPosted: Sat Jan 24, 2009 5:25 pm
PITA Old Fart
What Cat said....lol
PostPosted: Sun Jan 25, 2009 2:45 am
Ethanol sucks... It eats thru cork gaskets. It eats thru rubber gaskets. It eats thru glass. It eats thru fuel lines.
I haul gas for a living. The day I started putting ethanol in the gasoline I haul, everything on my trailer started leaking. I'm talking about a 6 month old $80,000 gas tanker trailer. All my site glasses cracked, the pump on my truck started leaking, and all my hoses started cracking.
Hopefully the government will wise up and stop requiring this crap to be added to our gasoline.
PostPosted: Sun Jan 25, 2009 3:57 am
i agree, before it got so frequent here in oklahoma i was getting around 30 mpg and love's truck stop had gas 30 cents cheaper than anywhere else so i stopped filled up,long story short i'm only getting 22 mpg now and going through spark plugs faster
PostPosted: Sun Jan 25, 2009 4:59 am
it is death to a plastec fuel tank, on a chansaw.
we go thru fuel tank filler o-rines fast.
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
PostPosted: Tue Jan 27, 2009 7:09 am
Thanks for the tip. Ordered the gasket set yesterday. If anyone else needs the gasket set it is Weber part #99005.333. It is not the whole adapter, just the 3 gaskets. $12.95.
PostPosted: Tue Jan 27, 2009 10:15 am
The Right Stuff is in my opinion some of the best sealant made, it's pricey but well worh it.
Users browsing this forum: Google [Bot] and 30 guests
