It is currently Mon Jun 08, 2026 5:36 am
 Post subject: need help!!!
PostPosted: Wed Jan 07, 2009 6:20 pm
hey everyone im new here and i get a question. my luv truck is an 80. im having problems getting it to run. it will strat up and run but u must keep strating it. as soon as you let off the from starting it it will die. im alittle lost and was wondering if yall can help me.
 Post subject: Re: need help!!!
PostPosted: Wed Jan 07, 2009 7:58 pm
These trucks have a bypass to give the coil 12 volts when cranking then when the key is let off the relay kicks in and runs power through the ballest resistor. You will need a VOM or test light and see if power is getting to in side of the ballest, if so a bad ballest, if not a relay problem or possible ignition switch. Get a manual, follow the elect schemo.
PostPosted: Thu Jan 08, 2009 1:12 am
Yup, With a volt meter measure both connections at the balast resister with the key on. Should be 12V on one, and 7-12V on the other depending if the points are open or closed at the time.
Bad balast is a good guess.
PostPosted: Thu Jan 08, 2009 2:51 pm
Is your choke stuck?
Mine did the same thing today. I have a weber. My power selenoid was not opening, but have not looked at the cause yet, if it was no power or just went bad.
