It is currently Mon Jun 08, 2026 6:46 pm
 Post subject: Fuel tank filler hose
PostPosted: Sun Oct 30, 2005 7:47 pm
I recently pulled the fuel tank out to flush it out and modify it to run larger lines to feed a bigger motor. I removed the nylon braided connector hose from the filler neck and promptly destroyed it. Is it possible to get a stock replacement or does anyone have a line on a suitable replacement? I'd hate to use a piece radiator hose but i'll do it to drive again.
PostPosted: Tue Nov 01, 2005 7:15 pm
good luck finding a new replacement. I'd be somewhat concerned about using a radiator hose though. i think gas might turn it to jello. a junk yard replacement or large hydraulic hose may work in this application.
Government... if you think the problems we create are bad just wait till you see our solutions
PostPosted: Tue Nov 01, 2005 7:55 pm
I recently found that NAPA sells generic filler hose by the foot. It goes for about 12 bucks. Summit sells some clear stuff with their filler/fuel cell kits. So 12 dollars sounds like a easy fix. When i get some, i'll post the part#.
PostPosted: Sat Nov 05, 2005 7:45 pm
I hit NAPA today and tried to get some filler hose. It turns out that they can only get it in 3 ft sections. Thats 36 bucks for filler hose. And i only need 5 inches of the stuff. Im going to look for something else.
PostPosted: Sun Nov 06, 2005 7:09 pm
I located some vinyl reinforced tubing on the internet. It's compatible for automotive and marine applications (NSF rated) and Home Depot was supposed to have the stuff up to 2" dia but they only had 1,1/2". 1.3/4" is the magic number. Tomorrow i'll check with the local Cat tractor co.
PostPosted: Fri Nov 11, 2005 5:29 pm
The NAPA part # is NBH 1035. I lucked out and found a store that had a 5" section that will work fine. Good luck to those who will have to pull a tank in the future.
PostPosted: Fri Sep 19, 2008 3:31 pm
IVE USED FLEX RADIATOR HOSE ON BAGGED HARDBODY FOR YEARS AND IT WORKED FINE
PostPosted: Sat Sep 20, 2008 12:21 am
Your NAPA store is jerking you around. I've purchased short pieces of fuel filler hose 4 different times from 2 different NAPA's, just purchased twice in the last 3 months. Your NAPA just prefers to stick you for a fatter sale.
PostPosted: Tue Oct 14, 2008 2:06 pm
I ran into the same problem
I recall it was like 30$ I hated cutting it shorter
and different parts store have different ways to do business
most napa around these are closed up
I'd take my old one down to a wrecing yard and try to match one up
PostPosted: Thu Oct 16, 2008 8:13 pm
i went through the same thing so i went to a john deer tractor parts store they sell gas hose in that size it was about $10 hope this helps
I will no longer do that thing with my tongue
Users browsing this forum: No registered users and 64 guests
