It is currently Mon Jun 08, 2026 4:34 pm
PostPosted: Sat May 31, 2008 2:01 am
i have a 1979 luv 1.8L auto and the tranny only has 1st and reverse no 2nd or drive
the guy i bought it from said it shifted fine when he drove it last but that was a year ago and sence than his son took off the cooler lines and pluged the holes with bolts and now i by passed the cooler and just looped a hose from one line to the other
do i need a new tranny or should this be an easy fix
also my friend has a 5-speed out of his s-10 will that bolt to my moter??
PostPosted: Sat May 31, 2008 8:03 am
Have you checked the fluid level????
Bob.
PostPosted: Sat May 31, 2008 1:51 pm
There is a high demand for 5-speeds. Maybe somebody knows if the S-10's 5-speed will bolt on to the G180. You also have the driveline to fit. Welcome to LuvTruck.com.
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Sat May 31, 2008 3:50 pm
i have checked the fluid level and when i disconect the cooler hose that pumps out it pumps fine
so i think the filter is good so now i am lost
i did find out that the cadilac fleetwood has the th200-4r tranny in it but i do not know if it is a direct bolt in
and it would be nice to have overdrive
PostPosted: Sat May 31, 2008 6:05 pm
I would check to make sure your vacuum modulator is hooked up and functioning properly.
PostPosted: Sun Jun 01, 2008 12:46 am
The Isuzu pup 5 Speed will bolt directly to your stock 1.8L.
Here's the link to the sticky in Drivetrain section:
http://forums.luvtruck.com/viewtopic.php?f=6&t=14306
Users browsing this forum: Bing [Bot] and 32 guests
