It is currently Mon Jun 08, 2026 11:59 am
 Post subject: So
PostPosted: Tue Apr 15, 2008 10:03 pm
I got me a carb right but its got the coasting richer soilnoid on it my old carb did not have it and I have no wiring for it would that make it die out after driving it ?
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
 Post subject: Re: So
PostPosted: Sat Apr 19, 2008 5:15 pm
What would of If i just it off
79 4x4 1.8 liter
PostPosted: Sat Apr 19, 2008 9:11 pm
If you remove it, you will have a vacuum leak, unless you plug the hole off somehow.
PostPosted: Sat Apr 19, 2008 11:52 pm
Won't hurt anything if you just leave it in place. Just don't hook up it's wire and the valve will stay shut forever, no vacuum leak.
PostPosted: Sun Apr 20, 2008 4:16 pm
but the truck wont stay runing it will die out when I let it idel after driving it
79 4x4 1.8 liter
PostPosted: Sun Apr 20, 2008 10:06 pm
You might be thinking about the idle stop solenoid. There were two different solenoid things sticking out on the carbs. One was the idle stop solenoid and the other the coasting richer solenoid. The idle stop one needs to have power when the key is on or it won't idle. If memory serves me correctly I believe the idle stop unit was a bit smaller in diameter of the two and had only one wire.
