It is currently Mon Jun 08, 2026 11:59 am
 Post subject: Timing Issuse...HELP!
PostPosted: Sun Mar 16, 2008 9:06 pm
ok here is the deal..i am going with a 81 1.8 in the daily beater of mine. and im having major issuses with the timing chain being a stubbrn brat on me cause the timing chain and sprockets are inside the block. anyone know any tricks and or how to get the timing chains right on target?
Stick Shift Racing
PostPosted: Mon Mar 17, 2008 3:31 pm
well, not knowing exactly what you are trying to do it would be hard to give you any pointers. as far as getting to the timming chain and sprockets, they are not located in the actual block but in the front cover of the motor, which you can get to by removing the head, water pump and then the aluminum cover.
PostPosted: Mon Mar 17, 2008 3:48 pm
oh ok thanks..on mine, when i had the head rebuilt sometime back and reinstalled the head back on the motor. somehow the timing jumped on the motor. and my dad and i spend 4 or 5 weeks trying to reset the timing on it and gave up on messing with it and parked that ol 81 luv long bed i had. on the motor you can put it back at TDC and adjust it. then the motor would run bout a minute and a half and it will jump timing. ive got a 4.3 V6 im thinking i just might go ahead and drop it into my 79 Luv.
Stick Shift Racing
PostPosted: Mon Mar 17, 2008 3:58 pm
sounds like your tensioner is not engageed or broke. you can get one at your local parts store fairley cheap.
PostPosted: Tue Mar 18, 2008 7:53 pm
yeah you have to make sure since you did a rebuild, that the plastic tensioner is still in place and engaged. you just use a flat head screw driver and twist it clockwise until it fully releases. a trick i use when doing that is just pushing on the chain itself so the tensioner engages fully. mine jumped time once and it sucked. that among other problems caused me to rebuild the engine. :-)
PostPosted: Tue Mar 18, 2008 11:55 pm
got it set....thanks guys. that tensioner on mine was wore out so i went in and replaced it
Stick Shift Racing
PostPosted: Fri Mar 21, 2008 2:29 am
sweet deal! so it runs and purs nice and quiet now right??? (laughs a little at a luv running smoothly. :lol: )
PostPosted: Fri Mar 21, 2008 8:29 pm
lol oh yes..i got a another question, well a couple of em..a friend of mine has a 78 model Luv shortbed with a 86 Isuzu engie upgrade. its a 2.2L gas burner. and he was wanting to install a header on it but pace setter shows a 2.3L over on summitracing.com, is that the same engine or will it work?
and is there other options on header than pace setter? like flowtech or hedman or hooker?
Stick Shift Racing
PostPosted: Fri Mar 21, 2008 9:57 pm
I dont know, but if you e-mail summit they typically respond by the next day. Ive always had very good luck e-mailing them questions.
PostPosted: Sun Mar 23, 2008 1:52 am
oh ok, ill shoot them a e-mail then. thanks
Stick Shift Racing
