It is currently Mon Jun 08, 2026 1:00 pm
 Post subject: blown regulator fuse
PostPosted: Thu Jan 10, 2008 3:17 pm
i have a 79' mikado 4x4 that after a year of sitting i finally rebuilt the motor. fired up no problem, it will sit at idle no problem, but when i go for a test drive up the street it seems like every time i hit third the regulator fuse blows out. i rechecked all my conections but it still happens. any ideas?
PostPosted: Thu Jan 10, 2008 5:26 pm
well i found out that the wiring harness plugs on the firewall for the carb and tranny are the same, i just crisscrossed them and she is running better than ever.
PostPosted: Fri Jan 11, 2008 4:42 pm
That will do it. The coasting richer solenoid switch kicks in when the tranny is in third or fourth and just connects to ground. Good tidbit to know.
PostPosted: Wed Jan 16, 2008 12:15 am
My 80 Luv keeps blowing the regulator fuse as well.
I have done some work on the wiring awhile back (I dont drive my truck much). Where were those two plugs on the wiring harness? I suppose I could just trace the wires from the carb. :D
PostPosted: Wed Jan 16, 2008 12:32 am
Very interesting. *I think* the carb plug is located on the passenger side of the harness, about halfway between the fender and the hood latch. It's a keyed 4 prong connector. Series 10 manual shows: BG, BY, LgW, B wire colors. Someone correct me if I'm wrong...
I have no idea what or where the tranny connector is, have I got my carb hooked to the wrong one? When you've got 5 posts, will you post pics milehighluv?
PostPosted: Wed Jan 16, 2008 5:05 pm
on mine, the tranny plug is the same type plug just a few inches away from the carb plug twards the middle of the fire wall.
