It is currently Mon Jun 08, 2026 2:14 pm
 Post subject: rear end help
PostPosted: Tue Dec 25, 2007 1:31 am
ok yesterday I took the luv out on the highway (first time ) sense I changed rear pumpkin gears... the truck used to be about 5 to 10 miles off on the free way I would say at about 80 on speedometer it would be running about 70/75 actual and just under 4k rpm... well now its off by a lot more then that , on the way to Portland it was pegged so say 90 to 100 and I know I was only doing about 70 and it was at about 4500/5000rpm so what did I do wrong?
PostPosted: Tue Dec 25, 2007 12:15 pm
The ring gear must have less (or more) :? teeth on it, right? Was it from a different year truck?
PostPosted: Tue Dec 25, 2007 12:41 pm
Swap Specialist Mod
sounds like you out a 456 geared 3rd memeber in it.
PostPosted: Tue Dec 25, 2007 5:18 pm
not sure what year it was out of
PostPosted: Tue Dec 25, 2007 10:46 pm
It just sounds like you went to a much lower geared ring.
PostPosted: Tue Dec 25, 2007 10:47 pm
so my 79 had a 3.73 and the newer on is a 4.10 wright?
PostPosted: Tue Dec 25, 2007 11:32 pm
you can do a general check... it wont be absloutely accurate, but it should get you close enough to take an educated guess as to what gear they are.
hold one tire, and mark the other tire. turn the driveshaft and count how many times you have to turn the driveshaft to get the wheel to go around one time.
Like I said, its not as accurate as counting the teeth, but it should help you to figure it out
PostPosted: Wed Dec 26, 2007 12:10 am
ok,
thanks
PostPosted: Wed Dec 26, 2007 6:44 pm
Swap Specialist Mod
a stock 79 should have a 410 geared rearend.
i could bet ya money that you put a 456 geared rearend in it.
PostPosted: Wed Dec 26, 2007 6:55 pm
thats what i thought it was originally was a 4.10 but i did a search and found something saying 3.73 for 79 so i figured ok... so what would the 4.56 come out of (year)
PostPosted: Wed Dec 26, 2007 9:03 pm
Swap Specialist Mod
456s would be from 72-75.
i have a 75 rearend in the pup and its got 456s.
PostPosted: Thu Dec 27, 2007 12:21 pm
one cool way (if you have not thought of it already) to check the accuracy of your speedometer is to get a hand held GPS. I had one I use on my sailboat. I have found that most of my vehicles are off a little bit
Current Fleet
pics
