It is currently Mon Jun 08, 2026 4:33 pm
 Post subject: Oil Pan Removal
PostPosted: Sun May 06, 2007 11:08 pm
sorry for the dumb question but....
Can you remove the oil pan with out removing the engine?
I thought you could. I heard guys reverence it on the forum. I have everything undone but now it looks like I have to remove the main tie rod to get it out. Do I really have to disconnect the tie rod? thought I would ask before I did something I regretted. :oops:
Current Fleet
pics
PostPosted: Mon May 07, 2007 5:19 am
You are most likely going to have to unbolt the engine mounts and raise up the engine to get enough clearance to get it off.
PostPosted: Mon May 07, 2007 6:29 am
If you don't want to raise the engine, and want the oil pan removed you have to remove the crossmember and the midlink, yes. Just back off on the locknuts a turn and stop so you can replace it when you're done without affecting the alignment. Be aware that they have opposite-hand threads...that is, the midlink attaches to both tie rods at the same time.
I would say the right side has right-hand threads, and the left side has left-hand threads. I used a 15-inch adjustable wrench to hold the midlink while I released the lock nuts.
Replacing the oil pan under the vehicle is not fun. You will also need to remove both of the braces on the rear of the block, one of which has the clutch cable going through it. I don't have an automatic, so I can't say what it looks like. Be sure you don't over-tighten the bolts on the pan and make the new gasket get damaged. My oil pan gasket said not to use any chemicals, but I had to use Permatex® to make it stay in place. I put it on the block first.
When I had the engine in the shop on a stand, it was a lot better. Especially since I forgot to include the oil pickup tube, and immediately had to do it over!!!
PS- That wasn't a dumb question; the manual describes it.
Here's a few views...
Image Image
The front; remember to apply sealant at the points where the steel block meets the aluminum brackets/The rear
Image Image
The oil pan/Herein lies the problem; see how the gasket doesn't line up perfectly with the holes?
Image Image
That's why I had to use Permatex®, because the rubber gasket wouldn't stay where I wanted it
Image Image
Much easier upside down on an engine stand!!!/Notice the even line of the gasket
Image Image
No protrusions, or bulging
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Mon May 07, 2007 7:26 am
Very good photo record of the pan job Fullaluv keep up the good work.
PostPosted: Mon May 07, 2007 7:36 am
Thanks TJ, and I hope it gives Gs11x a boost, as well as anyone else who looks. I have taken over 2000 photos of my LUV since I got it in September. I find myself using them over and over too!
Image Image
PostPosted: Mon May 07, 2007 11:03 am
Thanks Fellow Washington luvers. These guys are up at 3 and 4am in the morning to give me help. you can't buy this kind of support.
I guess I should read the manual before I posted. It was right there in the manual to disconnect the steering link to remove the pan for 2wd.
4wd you have to pull the engine.
Looks like someone did overtighten the pan because the gasket was split around one of the bolt holes. the pan is also bulged around many of the bolt holes. I think i will try to flatten some of them a little with my body hammer.
Current Fleet
pics
PostPosted: Mon May 07, 2007 12:31 pm
Yes, do tap them down a tiny bit, with a soft base like a furniture pad under the pan.
Image Image
PostPosted: Mon May 07, 2007 1:57 pm
The holes in most gaskets are designed to be small enough so that you can screw the bolts through them by hand and they will stay put holding the gasket in place while you install it all.
Another great trick to hold the gasket in place is to use sewing thread to tie the gasket to the pan.
Using permatex is like shooting yourself in the foot. If you have ever had to fight like hell to get a part off just to sit and scrape permatex off forever before you can put it back on, then you would know what I mean. That crap should be illegal.
 Post subject: Bullet vs. scraping
PostPosted: Mon May 07, 2007 4:11 pm
I'd rather scrape off Permatex than pull a bullet out of my foot. I like your thread suggestion. That's a winner, and I wish I'd known that. When I put the engine together in my shop I didn't use any Permatex on the rubber gasket except where the manual instructs us to, at the junctures of steel and aluminum.
Underneath the vehicle, I couldn't think of any other way, but your thread trick is a winner. Also, I didn't think to use the gasket's seeming malformation to hold the bolts. That would've been good too.
Image Image
PostPosted: Tue May 08, 2007 1:55 am
Another trick I did was have a few extra pan bolts with the heads cut off. Screw them in to hold the gasket in place, put the pan in place, then remove them and put in the regular bolts. And you are right-do not over tighten them.
PostPosted: Mon May 14, 2007 10:39 pm
I'm curious how this 'thread trick' works? Care to explain a bit more Taz?
PostPosted: Tue May 15, 2007 3:08 am
Take plain old cotton sewing thread and use it to tie the gasket to the pan through the bolt holes to hold the gasket in place while you are putting it and the pan back on. The thread won't cause any leakage and doesn't cause any problems if you just leave it there, or it can be cut and removed by pulling it out once you get all of your bolts started.
Also, for some odd reason, most G180's have studs sticking through in the bottom of the timing cover where it bolts to the oil pan. If you double nut them and lock the two nuts together, you can remove them to make it a lot easier to get the pan on and off. You can put them back in when you re-install the pan or just replace them with bolts like I did.
That way, if you ever have to replace your timing cover gasket, it makes the whole process a lot easier, since those pesky studs sticking through the oil pan make it darn near impossible to get the timing cover off with the oil pan still bolted on.
I mean, good grief, it's bad enough that you have to replace the head gasket every time you take the timing cover off, since the clever folks at Isuzu decided in their infinite wisdom to design an engine with two bolts through the head and head gasket into the top of the timing cover.
But studs through the front of the oil pan too?
That's pure engineering genius at work right there...lol
