It is currently Mon Jun 08, 2026 1:00 pm
 Post subject: Update on 383
PostPosted: Thu Feb 22, 2007 3:21 pm
The 383 is no more... It threw a rod...nice sized hole in the block, ruined crank, yeah i did a good job on that one...
PostPosted: Mon May 07, 2007 1:55 pm
on the bong
But it was fun while it lasted, huh?
PostPosted: Tue May 08, 2007 12:52 pm
yep
PostPosted: Tue May 08, 2007 8:14 pm
How'd it happen ? Revvin at nascar rpms ? How many miles did you clock on it ?
-Austin
PostPosted: Wed May 09, 2007 1:57 am
any pics of the carnage?
1975 V8 Luv
1980 Bagged Luv
PostPosted: Mon May 14, 2007 1:19 pm
nascar rpm's in first... got pissed cause it didnt want to shift out.. only found out later that the vacuum hose on my turbo 400 had a split in it... actually didnt blow when i was on the throttle. got gutless then i pulled up towards my shop and it was doing about 1500 when it went... lots of bottom end carnage. I've seen two motors blow like that, matter of fact! dont understand, why did they blow at low rpm's like that? the other hadnt really been revved much...
