It is currently Sat Jun 06, 2026 11:21 pm
 Post subject: shaved head
PostPosted: Sun Apr 13, 2003 8:10 pm
Does anyone know how much u can machine the head on the 1.8? I have heard that it improves power.
Power
PostPosted: Sun Apr 13, 2003 9:40 pm
Resident Sparktrician
It just so happens that I just got off the phone with a diesel mechanic in my family, and I asked a similar question. He told me that you don't want to resurface the head unless it is necessary due to warping. He said that the main reason behind this is that it will change the specs of your camshaft movement in a way that is less than desirable if you take off too much. So, the way that I understand it is that if there's no warping don't risk shaving. If you want to know how to determine if it needs machining, let me know and I will post it.
Hope this helps (I know it is probably not what you wanted to hear, but...)
Kuranosuke
Grampa's Driving:
1990 Luv 4X4 "Family Cab"
got BOOBIES? 8O 8)
PostPosted: Wed Apr 16, 2003 4:14 am
I have heard of a couple of places locally that are straightening warped aluminium heads by heating and pressing rather than just machining. If you've got a warped head try looking around for someplace that is capable of doing something more than just cutting metal off. If it is warped bad enough the cam will start to bind up and wear things out a lot faster even if the bearings are redone. Not to mention shaving will increase pressure on the head gasket, which is already a weak link on the LUV 1.8L.
PostPosted: Fri Apr 18, 2003 8:28 pm
OG Lifer
I have a shaved head. Oh you mean the cylinder head. Sorry, brain/beer fart.
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Fri Apr 18, 2003 9:00 pm
LOL! Yeah I get those too. Must be ann OKIE thing.
Kuranosuke
Grampa's Driving:
got BOOBIES? 8O 8)
PostPosted: Fri Apr 18, 2003 9:01 pm
also remember that the 1.8 is a zero clearance engine....meaning..at stock...it you break the timing chain, or it jumps a few teeth (like mine did :evil: ) ...it WILL bend valves!!
if you remove too much from the head you run an even bigger rick of bending valves
PostPosted: Sat Apr 19, 2003 9:29 am
OG Lifer
Larp, do the pistons have valve reliefs in a stock engine?
PostPosted: Sat Apr 19, 2003 9:38 pm
neither of the 2 sets of stock 1.8 pistons i have in the garage have them.
this reminds me. anyone in the mid west/east coast (i know we are few and far between :P :lol: ) need some 1.8 parts?
PostPosted: Sun Apr 20, 2003 10:40 pm
I used to have shaved head on my 75 4banger and when my chain snapped it didn't bend anything, mine still had clearance
PostPosted: Mon Apr 21, 2003 3:10 pm
:? ....maybe they changed something betewwn 1975 and 1980?
did yours have the jackshaft on the timing chain?
PostPosted: Tue Apr 22, 2003 4:45 am
jackshaft ? hmmm...never heard that one, though mine does have a layshaft (Haynes manual term). I assume they are the same thing. If i remember correctly they changed the head design the next year(76) after mine, that could be the reason for bent valves.
PostPosted: Tue Apr 22, 2003 8:04 pm
*in best Ed MacMann voice*
"Yes, you are correct sir" :lol:
layshaft is the term.....dont know where the hell i got "jackshaft" from :?
PostPosted: Fri Apr 25, 2003 1:56 am
nice :lol: ...kinda like that word "jackshaft"
PostPosted: Wed Apr 30, 2003 10:18 pm
ha ha ha he he said jackshaft
Users browsing this forum: No registered users and 56 guests
