It is currently Wed May 27, 2026 4:37 am
PostPosted: Wed Oct 24, 2012 3:17 am
Strange anomoly started up yesterday. As my subjust on this topic says, the "O" light is flickering. I did notice that it flickered more steadily upon left hand turns. and every couple seconds driving straight. What could do this... I have checked all wiring under the hood by the sterring wheel shaft. :/ Well Let me know guys and gals.
My House Is Guarded By A Shotgun 3 Days A Week. Guess Which Days.
PostPosted: Wed Oct 24, 2012 3:18 am
btw...These posts are the product of a ADHD mind during a Mid-night drink wake-up. :) Night you guys. :lol:
PostPosted: Wed Oct 24, 2012 7:35 am
I don't know what year truck you have, but mine only has a gauge for temperature and and O light for oil pressure... Check your oil.
PostPosted: Wed Oct 24, 2012 12:46 pm
i was about to say the same thing. i have 2 lights one for the alt "GEN" and one for oil. my oil light came on a while back and it just needed a new sensor.. take a pic of your dash and where the light is it may be something totally different.
only thing that should warn you of overheating is the temp gauge.
PostPosted: Wed Oct 24, 2012 8:31 pm
Thats something else that has been worrying me....that temp gauge stays low....I mean barely above warm.
PostPosted: Wed Oct 24, 2012 9:51 pm
O is the oil light. I think some trucks have a overheat light, but it has to do with the exhaust temps
PostPosted: Thu Oct 25, 2012 4:29 am
well...I am rolling with only the exhaust mani right now....until here in a few hours, I bought the dounut gasket yesterday. but It got dark real quick on me. :( BTW....For a 1.8, These lil buggers are freaking loud from 0mph to 45mph. then it hums out a lil. I think I have recieved hearing loss. lol
PostPosted: Thu Oct 25, 2012 8:03 pm
Is the thermostat removed?
PostPosted: Thu Oct 25, 2012 11:28 pm
not that i know of....ill check in the morning.
PostPosted: Sat Oct 27, 2012 9:34 am
mine usually stays JUST below the notch on the temp gauge, maybe the width of the needle away. if i run it at 70 for a few miles it will get just above but still only a needle width or so above
just for comparison sake :p
PostPosted: Sat Oct 27, 2012 7:15 pm
You are right on Mr. lol thats exactly where mine is.
PostPosted: Sun Oct 28, 2012 10:10 am
good than you should be all good for your running temps. i would change out the oil pressure sensor since its only a couple bucks just to be safe if the light is still coming on, when mine went out it would come on from idle to 1300ish rpm and then shut off once i hit 1400.
i like the "needle width" measurement since we dont have marked temps on the gauge :lol:
PostPosted: Sun Oct 28, 2012 3:59 pm
alrighty. Thanks brochacho! :lol: shoot...I was down in your neck of the woods yesterday. down off the 500. I-205 side. Had to go so my girl at her work....damn me being a hopeless romantic. lol
PostPosted: Mon Oct 29, 2012 9:20 am
man you were REAL close im like three blocks off of i-205 and mill plain right by the walmart
hey cant be all hopeless you have her right? :lol:
lemme know what happens with the sensor and if it fixes the problem, i bought a cheap one at cost less (ewwww) and had to change out the connector on my wire to accept a screw instead of slipping on like stock but it worked.
PostPosted: Fri Nov 09, 2012 7:32 am
well no that everything mechanicaly was fixed for a week....my charge light is staying on, but only just glowing faintly.
PostPosted: Fri Nov 09, 2012 9:57 pm
the GEN charge light? or the oil light still?
PostPosted: Mon Nov 19, 2012 8:49 pm
The Gen. light.
PostPosted: Tue Nov 20, 2012 2:57 pm
i had that issue too :lol:
mine was the alternator first time and the voltage regulator the second.
do you have a multimeter?
PostPosted: Thu Nov 22, 2012 3:42 pm
yup!
PostPosted: Thu Nov 22, 2012 9:35 pm
http://www.todayifoundout.com/index.php ... lternator/
should also check the battery before you start it and see how well it is holding a charge over night.
