It is currently Wed Jun 10, 2026 8:54 am
PostPosted: Tue Mar 28, 2006 7:14 pm
The dash as it came out of the box, I did cut out for the gauges and glove
The top grill did take some modifing to install. What I did was get a old grill and drilled out the plastic nubs that the clips go on to make a pattern
I then put my pattern over the new dash and drilled a 1/8 inch hole in the dash at each nub. Then I flipped the dash over and counter sunk a 3/8 hole, pushed in the good grill and was able to attatch the holders in.
Clean the metal to get it ready for adhesive
Put glue on metal and install new dash
Installed cluster, glovebox, and vents
Since the new dash was thicker, I had to trim down the top steering bezel to fit, this was done with a air die grinder with a sanding wheel on it
Now it is time to enjoy the final product, I am very happy with it. I do need to clean up the glove box door and cluster assembly, so I have something to do tomorrow.
The only thing I wish was different is I wish the radio area was a blank. I did not want to install a stereo, but now I will.
PostPosted: Tue Mar 28, 2006 7:28 pm
Damn that dash looks great I wish i could afford one but alittle to pricy for me. looks great though
PostPosted: Tue Mar 28, 2006 7:38 pm
Looks awesome :!: Good job.
Wish I had an extra $550 laying around.....
1980 2wd Stock
PostPosted: Tue Mar 28, 2006 7:42 pm
that is awesome!!
i wish they were cheaper though.. that is steep!
!!!FINALLY!!!
-1977 Luv mikado
PostPosted: Tue Mar 28, 2006 7:48 pm
A shop in Los Angles wanted 800 to repair a old one, but I had to find a decent one for them to fix, this was the lesser of all of the evil's I could find.
PostPosted: Wed Mar 29, 2006 11:06 am
you should think about painting your dash cluster now. the dash looks great but you can tell that the cluster is old. a can of spray paint should bring it back to black. ever think about white face gages? i know somone who makes the vinal decals that go ontop of the gages and it looks really good too.
80 luv 4x4, 2-1/2" torsion lift, 31x10.5/r15, 3" body lift, soon rear shackle lift.
85 monte carlo, goodwrench 350, cam, headders, intake, U know... the works.
PostPosted: Wed Mar 29, 2006 5:03 pm
I have plans of cleaning up the cluster and glove box this weekend. I have way too much money and time in this to even think about using a rattle can. There are products out there that will clean them up just fine. On Saturday it will be going over to a Detail/Reconditioning shop to finish the clean up.
PostPosted: Wed Mar 29, 2006 7:59 pm
with you throwing money around like that, it's no wonder you're so damned poor... j/k... anyway that looks sweet... i've been thinking of white faced gauges or going with some aftermarket stuff in mine.. it's kinda plain stock
PostPosted: Thu Mar 30, 2006 12:01 am
I will try to have some vinal gage sets made up along with some luvtruck stickers. I will let you all know if i can have my friend make them. If so how many sets should I have printed? 10,20? let me talk to the man and see what i can do.
