It is currently Tue Jun 30, 2026 12:00 am
PostPosted: Sun Feb 26, 2006 10:20 pm
Is the Luv lug pattern the same as the old Datsun 620s?
I've heard they are but just wanted to double check. I'm thinking of putting those wheels on my truck.
Also, on this Datsun site I go to the new craze is putting Nissan Titan/Armada wheels on their trucks using 1/4" spacers.
They're 18s and I was thinking if they all have the same lug pattern that I'd try to find a set of those.
2002 Lexus RX300
1998 Honda Accord
1977 Chevy Crew Cab Dually
1954 Ford F100
http://www.yvtruckclub.com/forum
PostPosted: Sun Feb 26, 2006 10:51 pm
yes they are the same and the old z71 and escalade wheels to and a few more and those old datsuns r sweet
PostPosted: Sun Feb 26, 2006 10:58 pm
ok, good to know. I've been looking at the Titan and Escalade wheels. That blue datsun above is mine. :)
2002 Lexus RX300
1998 Honda Accord
1954 Ford F100
PostPosted: Mon Feb 27, 2006 12:45 am
Swap Specialist Mod
damn, thats a clean dat!! i like them old ones
PostPosted: Mon Feb 27, 2006 1:40 am
I don't know if it's any help but here is a partial listing of stock 16" wheels that have the same bolt pattern. Offset and center bore spacing are shown, when I could find them.
Watch out for the center bore. Note that a lot of Chevys fit, except for the center bore (I don't know the stock 2wd Luv center bore).
Also watch out for the lug size. Luvs are 12m1.5 (12 mm with 1.5 pitch thread).
I ended up with some Tahoe wheels because they were real cheap. The center bore is too small for the front, so I will have to bore it out. Also the lug size was 14m1.5 and the holes were too big for my lug nuts. I ended up drilling the rotors and pulling in 14m1.5 lugs. I'll problably have 40 hours into my cheap wheels but I think it'll look good in the end.
Here's the table. Sorry for the wierd spacing. I didn't know how to make the columns line up.
Vehicle, WheelSize, LugSpacing, Offset(mm), StockTireSize, CenterBore(mm)
Luv 4x4, 14x4, 6x139.7, , , 91
Chevy Silverado 1500 (6 Lug), 16x6.5, 6x139.7, 29, 235/75/16, 78
Chevy Avalanche/Suburban, 16x7, 6x139.7, 31, 265/70/16, 78
Chevy Tahoe/GMC Yukon, 16x7, 6x139.7, 31, 245/75/16, 78.1
Mitsubishi Montero 6x139.7
Nissan Frontier, 17x8, 6x139.7, 40, 265/55/17, 100.1
Nissan Titan, 18x8, 6x139.7, 25, 265/70/18, 78
Nissan Exterra, 15x7, 6x139.7, 40, 215/65/15
Nissan Pathfinder, 16x7, 6x139.7, 21, 255/65/16, 100
Toyota 4 Runner/Tundra/Sequoia/T100, 16x7, 6x139.7 15, 265/70/16, 106
Toyota Landcruiser 93-97, 16X8, 6X139.7, , ,
Here's my wheels in the rear.
You went there in that?!?!
