It is currently Fri Jun 19, 2026 3:10 am
 Post subject: will this carb work?
PostPosted: Fri Dec 02, 2005 12:59 am
the carb is a weber 32/36 dgv the other numbers are 5a 283 02 it supposedly came off a datsun didnt know if it would work or not?
PostPosted: Fri Dec 02, 2005 9:21 am
LUVTruck.com's Cornholio
Yeah it'll work. You gotta have an adapter plate for it though. Those are good carbs. Real nice and clean looking. I had one on my ol' Toyota with a 22R. They are loud little suckers though.
PostPosted: Fri Dec 02, 2005 11:09 am
I think the adapter plate for at least some Datsuns is the same as the one for a LUV. You might luck out if you got the plate with it.
PostPosted: Fri Dec 02, 2005 11:40 pm
cool i think the plate comes with it ill have to check. Can u see and feel a consideral amount of difference with the stock engine with these carbs.
PostPosted: Sat Dec 03, 2005 12:28 am
also does a 32/36 dgav work on luv engines or is it just dgv
PostPosted: Sat Dec 03, 2005 11:24 am
On my old Toyota I did notice a little bit of increased power. But not only that there is only one vacuum line and thats to the distributor. It looks so much cleaner and eaiser to work on compared to that Asian carb, with a thousand vacuum lines, I had.
PostPosted: Sat Dec 03, 2005 9:22 pm
ok i know now that the32/36 dgav is liquid choke. But do you have to hook that up and if so can i just plug it off. I live in the deep south hardly ever use choke. doesnt get cold enough really.
PostPosted: Sun Dec 04, 2005 12:04 am
Banishment Pending
you could plumb it up so that it works right,tying it in with near by hearter hoses, or you could just yank off the water choke part so that all you have is the choke connecting rod thingy, and then just put a manual choke on it.
PostPosted: Sun Dec 04, 2005 1:22 am
cool thanks now i just need to find one that dont cost an arm an a leg
PostPosted: Mon Dec 05, 2005 4:43 am
The DGV is the series designation. The DGEV is electric choke , DGAV is air choke. Thats the only diference, as far as performance for those guys youll notice some more.
Users browsing this forum: Baidu [Spider] and 45 guests
