It is currently Sun May 31, 2026 4:43 pm
 Post subject: Need advice quick
PostPosted: Mon Dec 16, 2002 5:37 pm
Alright i had a tire blow out on me today. So right now im running on the back one of the stock 26" bfg all terains and on the other side a 25"street tire. My question is will this do anything bad to the rearend or anything?
Thanks in advance.
PostPosted: Mon Dec 16, 2002 5:51 pm
i dont see how its only 1" diff.
in the long run it may tho, so id get the correct one b4 too long
PostPosted: Mon Dec 16, 2002 5:56 pm
take larps advise. get a new tire pronto. the difference in tire size can be detrimental to your rear end. see, one side will turn faster than the other causing the spider gears to turn at different speeds. this is like jacking up one side of the truck and allowing the other side to still be on the ground, while allowing only one side to rotate. your spider gears will heat up and eventually become brittle and possibly shatter. it happened to a buddy of mine in a ranger pick-up. n e way, yes get a new tire. :wink:
PostPosted: Mon Dec 16, 2002 5:59 pm
OG Lifer
i forgot to login :oops: oh well
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Mon Dec 16, 2002 6:07 pm
well it may be a while untill i get new tires just talked to my dad about it and we will go tire shopping (was going to get a set of BFG all terains but they are back ordered 3-4months 8O ) and get my christmass present a bit early (good off road tires for the beast). Untill then im just switching the bigger tire to up front. That wont do anything as long as i dont use 4x4 right.
PostPosted: Mon Dec 16, 2002 6:28 pm
it may be better to swap one of your front tires out so the ones on the back match. that way the smaller tire is on the front. course then you would have to be easy on your 4x4
PostPosted: Mon Dec 16, 2002 6:30 pm
please ingore last post b/c im a dumbass and didnt read all of your last post. :oops:
GAWD i need another mikes :)
PostPosted: Mon Dec 16, 2002 8:16 pm
:rofl: :silly: :crazyeyes: :multi: :shocked!: Thats funny!!
PostPosted: Mon Dec 16, 2002 9:04 pm
hey just remember, "people come and go, but alchahol will always be there for you"
PostPosted: Mon Dec 16, 2002 11:15 pm
Hey MEPR,
Just in case those tires you're switching are any good don't leave them on the front for too long either the will wear unevenly and probobly make you truck pull one way, Not a big deal if your not running like that for a short period thou.
Hope this helps...
Dave
PostPosted: Tue Dec 17, 2002 7:04 pm
yeah well my truck only got a grand total of 10miles on it that way (i drove my bros car today). And i have new tires. Only now i have a diferent problem, 27.5" A/Ts dont clear too well. Oh well every offroader knows the sawzall is his friend! Time for some fender trimming! :roll:
 Post subject: advice
PostPosted: Tue Dec 17, 2002 7:16 pm
Where are your tires hitting the fenders? If it isnt too bad , just use a baseball bat and roll it between the tire and the fender while rolling the truck and it should clearence the fender pretty well without unsightly creases. Just take your time doing it. That is the way I did mine.
1980 4X4 LUV
PostPosted: Tue Dec 17, 2002 7:40 pm
OR..... you can run it till it breaks, then you can tell your wife or whoever that since its broke, you might as well tubb it out. This is how it was for me. :lol: then go shopping for the ford 9, baby. Now this is some good down home advice. dont mention it. 8)
"G"
PostPosted: Tue Dec 17, 2002 10:12 pm
nah all the more reason for the lift! :twisted: :D
PostPosted: Tue Dec 17, 2002 11:37 pm
when i put my 30 on my 4x4 before it was lifted the just barely rubed and the only place the rubbed was on the front fender on 1 of the places it bolts
