It is currently Sat May 30, 2026 10:43 pm
PostPosted: Sat Nov 02, 2002 5:21 pm
hey everybody out there who has already done your v 8 swap do you guys still run the stock electric fuel pump???? if not did you guys switch to a better electric or did you just run a hose from the tank to your eccentric on the block of the v8 i need help thanks alot :P
PostPosted: Sat Nov 02, 2002 5:25 pm
I blocked off the stock mechanical pump and used a Westbay Auto Parts generic electric pump. My stock electric pump was bad. John
 Post subject: pump
PostPosted: Sat Nov 02, 2002 5:53 pm
I did the same but run a paxton150. Bryan
PostPosted: Sun Nov 03, 2002 1:24 am
you cant use the mechancial pump it wont fit .because i have 400hp i use a 160gph pump ,but with the stock 350ci i used the aftermarket electric pump worked fine for 5yrs
PostPosted: Sun Nov 03, 2002 6:23 am
It depends on who puts the engine in.I have had 2 with small block Chevy's and both had stock mechanical fuel pumps.Both also had home made mounts.I am running stock mechanical fuel pump on my big block for the engine and planning on putting a electric one on it for the nitrous.
stripped and just a memory!
 Post subject: thanks guys
PostPosted: Sun Nov 03, 2002 10:12 pm
hey ratnluv do you by any chance have drawings+specs of your motor mounts if so i would like to see these thanks again guys
PostPosted: Mon Nov 04, 2002 7:06 pm
I used factory style chevy V8 1970 caprice mounts.Square tubing that fit between bolt holes in the mount.Cut square on the mount end and at the needed angle to weld to the frame.You can see it if you look in the post on the Mustang ll front end. Also look in the photo gallery under
Scott Howard 78 Georgetown Tn.I have also put a small block in a Luv and a 350 Chevy in a Mustang making mounts this way.
