It is currently Thu Jul 02, 2026 10:33 pm
 Post subject: Friday at the Track
PostPosted: Fri Sep 26, 2003 8:54 pm
OK I know that there are several of yall that go a lot faster than I do BUT how many can truthfully say that you can drive your truck to and from the track, back and forth to work and home EVERY day!! Well I only got $ 700.00 in my motor and do just that with mine and had my best ET ever tonight. My truck went 12.642 @ 107.39 in the Quarter. that is without any power additaves at all on 87 octain pump gas!!!!!
GOTTA LUV THE LUV
LATER SPANKY
GOTTA GET A NEW LUV!!!!!!!!!
PostPosted: Sat Sep 27, 2003 12:20 am
The thing is that as long as your happy, thats all that counts. Clearing 100 mph in the quarter is pretty respectable. If you smile when you look at your time slip, life is good.
 Post subject: keep smiling
PostPosted: Sat Sep 27, 2003 8:31 am
As long as your happy,to hell with with everyone else.12s are freakin respectable,damm respectable with a 700 dollar motor.So you go have fun Sanky and be happy,cause some people like me cant evenget there luv going ...........YET.lol :drinking:
PostPosted: Sat Sep 27, 2003 9:17 pm
But one day I can see it now **** Headlines LUV TRUCK .COM Rents the dragstrip for the weekend!!!**** yes we will have so many members thaat we will lease the track for a weekend... and Donny just bring all your parts over you will RIDE after a couple of hours of hard work you will bbe on a RIDE .... later Spanky
PostPosted: Fri Nov 14, 2003 12:24 pm
reaction?
PSN=Big Bad Barstow
NCRW Gaming Clan
My FaceBook
PostPosted: Fri Nov 14, 2003 2:15 pm
Whats in the motor?
or what kind of set up are you running?
PostPosted: Fri Nov 14, 2003 2:28 pm
it is a 350 4 bolt bored .040 over with keith black hyperyoublowits. A lunaiti cam 00012 , that is 515 lift and 2?? duration.It has STOCK 305 heads with little valves a Team G power ram intake with a 750 HP holley. the set up is a lief spring pro street LUV 4.56 gear with a locker. Best et to date was a 12.624 @ 107 mph and I drove it to the track and back home after the racin that night ...
PostPosted: Fri Nov 14, 2003 7:17 pm
That sounds exactly what i am building right now, its a 350 60 over 11:1 with 441 heads. Its got one of the older edelbrock single plain intakes on it. The cam is a cheap summit, its like 510 lift and 245 on the duration. turbo 350, 9 inch with 4 56 and a mini spool. We just narrowed the rearend last night and now i am waiting on the axles. Shit man i was hoping i would get this one into the mid 13s. If not im gonna have to put the gernade juice on it. :D
PostPosted: Fri Nov 14, 2003 7:58 pm
nice. thats a perty good time. I personally think nobody realy has any braging rights untill they drive the rig to and from the strip and do well. Im the same way whith mud racing.
PostPosted: Fri Nov 14, 2003 8:54 pm
Rusto with your 11.5 to1 comp ratio you should be in the low 12's depending on your tire size the 4.56 may be to much for the 1/4 mile. mine is turning approx 6000 at the traps. I got 31-16.5 x 15 MT ET streets on mine. And I only got 9.5 to 1 comp ratio too. ................
The next motor is in the works ... I was gonna build it but I am now thinking about just buying 1 from a guy. We built it and it has 10 passes on it. Get this now a 18* 434 small block ( tryin to hide a large smirk) it made 780 HP on our engine dyno at the shop !!!!!!! that was WITHOUT any gas ... ( spanky thinks he will install a big shot plate ) LOL
LATER SPANKY
PostPosted: Fri Nov 14, 2003 8:56 pm
DAMN Donnie your a GURU I am just a regular ..... oh well I will be there tooooo LOL
PostPosted: Fri Nov 14, 2003 9:12 pm
ive got 31 10.50 15 on it now. How many leafs do you have in it? and how well does it hook?
PostPosted: Fri Nov 14, 2003 9:47 pm
I have a setup alot like you guys and i have about $700 in my motor. Its a .040 over 350 with trw cast flat tops,double hump heads 2.02 1.60 valves
victor jr intake with a 2" spacer,comp cam 244@.050 int and ex .501 lift.
750 holley double pump,125hp nitrous,3800 stall,9in with 3.70 gears. I have problems with traction.Thinking about ladder bars next spring.
Best times
12.343@107.7 60ft 1.724 (motor)
11.355@118.1 60ft 1.616 (nitrous)
Kevin
