It is currently Sat Jun 13, 2026 10:01 am
 Post subject: PARTS COMPATABILITY LIST
PostPosted: Thu Jul 19, 2007 11:51 pm
Australian LUV Guru
I was looking thru my 81-86 pup parts catalog and noticed that a lot of parts look the same as used in 72-80 LUV's. Is any one interested in making a list of known interchangeable parts?
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Fri Jul 20, 2007 12:56 am
Sounds good.
PostPosted: Fri Jul 20, 2007 4:51 am
Australian LUV Guru
I'll get the ball rolling then, here are some parts outer 81-? Luv/PUps that can be used in 72-80 LUV's.
Front hubs/ disks
Rear axels/ diff centre/ diff housing
4wd front diffs/ housings
Window winder handles
Gas engines/ transmissions
Steering box manual& power assist. (some mods needed)
Im sure theres many more, chime in if you know some or disagree.
PostPosted: Fri Jul 20, 2007 7:25 pm
rotors and calipers from a 81 up truck will work on a luv?!
id love to have vented rotors on the luv.
PostPosted: Fri Jul 20, 2007 11:02 pm
Australian LUV Guru
Not to sure on the vented rotors fitment, but the solid rotors are the same. Maybe if you use the 81 vented rotor/hub/caliper and spindle as whole unit it will work in pre 81.
PostPosted: Tue Jul 21, 2009 12:18 pm
We should get this list going again. Anything you know that is interchangeable post up then we can start a new thread with all of it together and make it a sticky.
Insane Kustoms Car Club
www.insanekustomscc.com
Users browsing this forum: Google [Bot] and 12 guests
