It is currently Sat Jun 13, 2026 2:41 am
Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Dec 25, 2006 5:48 pm
I added an update of what the aftermarket rear sway bar would look like around the 9".
Go back to the 1st page as I edit'd it into what I had already posted.... :?
72 L.U.V.
427 SBC-700R4
Mustang II front suspension
LUV perf parts manufacturing
My Devotion to Karl :
PostPosted: Mon Dec 25, 2006 9:05 pm
Luvrv8 wrote:
When you are ready I bought a spray in bedliner company, I think it is around 225.00 my cost of materials and I can do colors and designs.
sounds like i need to come visit... :wink:
PostPosted: Mon Jan 08, 2007 12:38 am
Well, I went over to the FAB shop yesterday...
He has cleared the plates off the housing and indexed the housing to check for trueness.
The backside of the housing is now having a custom made rear truss box made for it; a unit much stronger than the aftermarket units one can buy.
I went overkill on this thing; why? I dunno, because we could I guess...We had the opportunity to do so so we did it! :?
We have designed it to fit within the inside dimensions of the LUV spring locations; so no issues at all.
After that is done, we will incorporate a breather fitting; adjust the fill location, and then set the new spring perches on.
So far they have yet to arrive from the machine shop.
Any day now I hope.
Once that is here we will try out our newly purchased pinion angle gauge assembly.
I, along with the FAB guy, will assemble this all ourselves.
This will be my first rear axle build.
I am restless to complete this.
Pics will be posted once I remember to bring my camera next time... :x
8)
72 L.U.V.
427 SBC-700R4
PostPosted: Thu Jan 11, 2007 9:11 pm
nice build up
PostPosted: Thu Jan 11, 2007 11:53 pm
Thanx!
I am still awaiting my spring perches....its rather frustrating awaiting on those who dont fulfill their end of things, IMO!
72 L.U.V.
427 SBC-700R4
PostPosted: Fri Jan 12, 2007 12:42 am
Very interesting thread. I still gotta get my LUV running! I like reading about your stuff and seeing your photos too. Hope it all goes together well.
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Fri Jan 12, 2007 12:58 pm
the pinion angle was tough for me to set . I ended up 6* off and had to use wedge plates . I had never set one up before .
PostPosted: Fri Jan 12, 2007 11:23 pm
6* ?
ooops
Perches arrived today, off to the shop for set-up attempts.
Ordered a pinion gauge, grade 8 carrier studs, and a new pipe vent fitting for the housing.
Seems Im ready to go to set this all up!
I will post some pics maybe later with some updates of the progress.
8)
72 L.U.V.
427 SBC-700R4
PostPosted: Sat Jan 20, 2007 11:08 pm
Well, what a long past two weeks this has been! :(
Delays as always in receiving things.
The housing is all jigged up.
We have a fixed tool to mount the housing to make planetary dimensions with for bracketry and pinion stuff.
Pinion angles and flanges we can now install and measure;
Thanx Luvsadrag and Juan! 8)
What an advance for me to say. I never thought I'd ever do rear axle stuff!
So, once we fit the housing into the stock leaf stuff, we will remeasure it all to double check our findings.
After that the welds will be finished off and I will tank the housing prior to assembly.
The carrier and new posi unit will be assembled and once installed, we will measure for axle needs for being made.
I think I have the hang of it now!
We have a rather grand view of all of this that something is now in the works.
We will keep you informed on our advances!
72 L.U.V.
427 SBC-700R4
PostPosted: Thu Jan 25, 2007 6:44 pm
update...
ready for the carrier re-build.
this is what I have at this moment:
post has been moved, sorry.
72 L.U.V.
427 SBC-700R4
PostPosted: Thu Jan 25, 2007 8:27 pm
:smt023
PostPosted: Thu Jan 25, 2007 9:25 pm
Man that thing looks tough . What size tire you plan to run?
PostPosted: Fri Jan 26, 2007 12:34 am
Right now I have a 15 X 7 rim, tires yet to be determined.
Once we have the axle measurement figured out, I need to look at the brake system and offset allowance.
Then I can play around with tire and rim width.
72 L.U.V.
427 SBC-700R4
PostPosted: Fri Jan 26, 2007 1:05 am
you going to rear disc's?
PostPosted: Sat Jan 27, 2007 9:39 am
havent decided yet...
thread has been moved.
Thanx!
8)
PostPosted: Sat Apr 12, 2008 9:43 pm
DRUMS done!
DISCS done
72 L.U.V.
427 SBC-700R4
PostPosted: Sun Apr 13, 2008 1:42 am
is that the one we whent to pick up?, looks great
PostPosted: Sun Apr 13, 2008 2:01 am
YUPP !!!
It's all engineered to drop in!
From Drums to Discs, YES!
We even got the drum conversion to connect to the factory LUV cable system.
Been alot of R&D in doing this!
72 L.U.V.
427 SBC-700R4
