It is currently Sun Jun 28, 2026 12:35 am
Post new topic Reply to topic  [ 246 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13  Next
 Post subject: Re: truck pic's
PostPosted: Mon Apr 06, 2009 12:13 am
mytmouz wrote:
Well, it blew through, no rain at the track 30 minutes away. So I got in 3 passes. First pass, no burnout as I couldn't get the line-loc to hold. Second pass was a turd as the carb gassed the plugs. (Sitting mostly for 2 years, not the carbs fault...) Third one was the charm. Launched hard and straight on motor. Couldn't get stopped before the return road, which has NEVER happened on motor before. Get to the time shack, the computer malfunctioned, so no timeslip... :smt013 That was my last pass as there was something bumping underneath as I drove back down the return road. It was late, so I called it a night. All in all, better than I expected, nothing broke. That I know of, unless the mystery noise turns out to be something. I do know my archrival was parked next to me, and after that third pass, he looked in my truck and didn't see a bottle in it when I returned. The noise I heard about a little grudge earlier run got VERY quiet... :lol:
Also, the alt. setup worked flawlessly, and the vacuum pump setup pulled 12 hg. So something went right at least...
PostPosted: Mon Apr 06, 2009 7:52 am
sounds like it was all good except the mystery noise...i love the way you put the archrival got quiet when he saw no bottle comment in there...that's a kodak moment!
PostPosted: Mon Apr 06, 2009 11:45 am
Its good to here someone made it out to the track and had some fun. We still have snow on the ground here :smt044
PostPosted: Mon Apr 06, 2009 12:01 pm
I saw snow on tv once... :D
PostPosted: Mon Apr 06, 2009 1:58 pm
Glad it went good for ya . Feels good when it pulls hard and goes straight huh .
PostPosted: Mon Apr 06, 2009 5:40 pm
Awesome!!! Hope you get the noise figured out. Which I'm sure you will. :D
PostPosted: Mon Apr 06, 2009 7:13 pm
If you click the link below, to the left at the top there is a small set of rotating pics of some of the cars at the race. I am the 3rd from the end and also the last pic, I think. You can right click, on the gif, click on zoom, and hit full screen to see larger pics. WARNING! There is some serious smack talk and strong language on the page, not kid safe!
http://www.bigbracing.com/MESSSAGEBOARD.html
PostPosted: Mon Apr 06, 2009 7:47 pm
Some good pics and some really nice cars and truck!!
PostPosted: Mon Apr 06, 2009 10:58 pm
Glad you made it to the track those are some great pics. Looks like you could probably find a street race pretty easy where you come from :D
PostPosted: Mon Apr 06, 2009 11:01 pm
Lot's of that goes on, with a lot of the cars in those pics...
PostPosted: Sun Jun 21, 2009 6:02 am
My mystery noise turned out to be a broken bolt holding the right rear coilover. It was allowing the spring plate to hit the bracket...
PostPosted: Thu Sep 10, 2009 12:26 am
(*&^%@(*&^$( Brakes! I have fooled with them for the last 2 weeks, trying to get a few test passes in before my track rental. New master cylinder bad, and brittle stock brake lines drove me nucking futs! It's all good now though...
PostPosted: Fri Sep 24, 2010 11:02 pm
Man, looong time, no update...
I put on a race, which I lost to a BBC LUV, (632 cubes and 3 stages, stuck transbrake let him get 4 on me, I caught 2 back up, no high gear on shift or it would have been interesting...) due to the brakes and subsequent tranny issue in OCT. of last year. I reworked the front end with the DHP tubular control arms and mustang II spindles and wilwood discs, solved the brake issues, I think. Subsequent race found the tranny was toast under load, worked fine as long as you were just puttering around. Pulled the tranny and repaired, test-n-tune will commence at first available opportunity...
 Post subject: Re:
PostPosted: Thu Oct 21, 2010 8:52 pm
mytmouz wrote:
It is amazing how long it takes for the local distributor to get a set of copper head gaskets, the &*$$*$#...
is this for 1.8 or for the sb 350 head gaskets if for the 1.8 what place you get them and how much
PostPosted: Fri Oct 22, 2010 9:56 am
SBC...
PostPosted: Sat Nov 06, 2010 3:31 pm
Some suspension pics...
PostPosted: Wed Mar 30, 2011 10:35 am
PostPosted: Wed Mar 30, 2011 11:40 am
8O That tie rod extension is a little scary.
PostPosted: Wed Mar 30, 2011 8:48 pm
lol, that was for mock up, not like that now, just almost like that...
PostPosted: Thu Mar 31, 2011 9:24 am
Since the LUV a arm cross shaft is on a different center than most of the rest of the world, I had to do some modding. I sectioned it this much...
Since the new cross shaft is made from tubing, I cut a piece of round stock and machined it to interference fit inside, beveled the edges, tacked the bottom of the bevel to the round stock in the center in a series of stitch welds with the mig, then made 3 passes to fill in the bevel. I used the stock centershaft as a jig by bolting the 2 shafts together to be sure the holes were both centered and parallel. After it cooled completely, I used a file to bring the weld down to roughly the same diameter as the tubing, stripped the plating off the entire cross shaft, and gave it a few coats of black primer. This is the finished product (except for color, not sure what yet) on the arm on the right. The one on the left is a set of tubulars I am using for measurements.
This is how much I have in change on the ball joint center right now (rough guess) should be plenty of adjustment now though...
