It is currently Fri Jun 12, 2026 10:46 pm
 Post subject: 1.8 performance ?
PostPosted: Tue Nov 19, 2002 8:03 pm
have a 81 luv 4X4 but want a little more power
need help finding performance parts for the 1.8 . any ideas ?
PostPosted: Tue Nov 19, 2002 8:12 pm
The search button would be an excellent place to start.
Is smog a concern for you?
If at first you don't succeed, try it like your wife told you to do it.
PostPosted: Tue Nov 19, 2002 8:26 pm
no smog is not a concern for me
 Post subject: 1.8
PostPosted: Tue Nov 19, 2002 8:41 pm
As Ben said i would use the search button. Most people according to what ive read ,is use a header and a Weber carb. Good Luck, Bryan
PostPosted: Tue Nov 19, 2002 8:58 pm
i have a weber carb . but mybe i will try a header. thanks
PostPosted: Tue Nov 19, 2002 10:26 pm
OG Lifer
cant go wrong with a k&n filter. they give you a gain in power but the big advantage is the way they supply VERY clean air to your engine. some folks think you get a 15 horsepower gain. well WRONG! you get a 15% gain in total horsepower and performance. i recommend these filters cause they are cleanable and have a million mile warrentee. ( i am almost there :wink: ) seriously, for your engines sake and your carby's sake, get a k&n. oh yeah, i almost forgot, SAY IT WITH NITROUS!!!!!!!! :twisted:
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Tue Nov 19, 2002 10:27 pm
OG Lifer
remember, not much at all in hp gain(for an 85 horse engine, 15% is diddly squat). thats all i have to say about that. (forest gump)
PostPosted: Thu Nov 21, 2002 11:54 pm
Hey my 4x4,
I also have an 81 4x4(Yellow, with a BIG dent all down the pass side).
Previous owner port rounded a lincoln in a parking lot. anyway, I got a header from J.C. whiney catolog 2 years ago 114.95 it's made by pacesetter the people who make monza tips. It is a night and day difference in power. Hope this helps...
Dave
PostPosted: Fri Nov 22, 2002 3:44 pm
OG Lifer
NITROUS I SAY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :drinking:
PostPosted: Fri Nov 22, 2002 5:02 pm
for the header
http://www.7453217467431.com/products/p ... 8005601203
PostPosted: Fri Nov 22, 2002 5:16 pm
How cute!!! :lol:
PostPosted: Fri Nov 22, 2002 6:50 pm
on my luv i have a 380cfm webber carb on mine a header (pulled it off a 77 it looks like the stock one but its aboput twice as big around) and i got an intake (just took the stock and had it smoothed out and enlargened like a port and pollish x2) and bore it .40 over. That thing is a monster i estimate its putting out anywhere from 110-140 hp and about the same for torque (but action is what counts and it pulls full sized trucks from mud pits :wink: ). It is just realy hard to find parts for the 1.8L. If you whant a lot more power and havea little time and money the v-6 from 81-82 S-10s bolts right up just need to mod up some motor mounts.
PostPosted: Fri Dec 06, 2002 6:44 pm
Hey Mepr the S-10 V-6 is a straight bolt up to the 4 speed?? lemme know......I know where I can get a S-10 of that year with good V-6 for a couple hundred bucks. It might just hold me outuntil I can get my V-8 plans worked out. lol
PostPosted: Sat Dec 07, 2002 12:48 pm
I had dual side draft carbs on my 1.8 and 2.0. I still have the rare manifold for the G180 and G200 motors. I have never seen another one. I ran dual 44mm Mukuni carbs, header, milled and ported cylinder head, custom made cam, lightened flywheel, 5-speed transmission,electronic ignition with modified distributor. It was pretty fast for a 4 cylinder. It ran low 16's in the 1/4. It use to rev to 7500rpm!
Mike & Chanin Saiki
http://www.motivational.net
PostPosted: Sat Dec 07, 2002 6:42 pm
yeah the s-10 v-6 should be a straight bolt up ill try to get a hold of my friend who did it. Oh and i finally got the pace setter header on my truck. Oh man that thing is well worth it. But be carefull i almost got a 15mph over ticket becouse i was driving it like i did before the header :oops:
PostPosted: Sun Dec 08, 2002 10:46 pm
i want to know more about the s-10 v-6 as well cause i might be able to get my hands on one as well. would i have to make n e oil pan mods on a 4x4 model?
PostPosted: Tue Dec 10, 2002 7:33 pm
i dont know for shure i have been trying to get a hol of mike but he has dropped off the face of the planet. Ill tell you guys if i can get ahold of him.
