It is currently Fri Jun 12, 2026 10:49 pm
 Post subject: Fuel Filter Problems
PostPosted: Sat Aug 28, 2010 8:15 pm
As I continue to work on the non-running '76 I decided to replace the fuel filter. Well the hoses were so old and brittle that they broke as I tried to replace the filter. Now I'm at a stand still until I can replace the hoses. Has anyone replaced these? Upgraded? I'm just looking for ideas. Thanks guys.
James Bates
 Post subject: Re: Fuel Filter Problems
PostPosted: Sat Aug 28, 2010 9:02 pm
No big deal. Pick up some 5/16'' fuel line at any hardware or auto supply. It is tight quarters fitting it on the gas tand outlet, but fairly easy otherwise.
PostPosted: Sat Aug 28, 2010 9:10 pm
had to put a fuel pump(electric) on mine to get it home. half way there a rubber line that i disturbed while doing it broke. lucky my wife was behind me and flagged me down before i pumped 10 bucks worth of gas out on the hwy
luv less for the time being
PostPosted: Sun Aug 29, 2010 11:07 am
Thanks Labman, I'll look in that direction. Jeramy I think I'm gonna have to replace the fuel pump too. It's in rough shape. The old fuel filter was full of debris, and the gas was brown and dirty when it drained out.
James Bates
PostPosted: Sun Aug 29, 2010 11:32 am
thats why i had to replace mine.it had 2 inline filters before the pump. the one closest to the tank was so clogged that i couldn't even blow threw it. i took it out and hooked everything back up but the pump was toast so there went 50 bucks.changed pump and filter.
PostPosted: Sun Aug 29, 2010 12:10 pm
Where did you find a pump for $50? Advance autoparts quoted me $90!
James Bates
PostPosted: Sun Aug 29, 2010 12:20 pm
just by a cheap mr gasket universal pump... your better off and they work just as well
PostPosted: Sun Aug 29, 2010 1:25 pm
Thanks Jeremy. I'm concerned that once I go to all the trouble of re-piping the broken fuel hoses and replacing the pump the gas tank is going to be so full of crud I'll be stuck again.
James Bates
PostPosted: Sun Aug 29, 2010 1:28 pm
oreilly auto parts
BesTest Fuel Pump - Universal Fuel Pump
Part Number: BE8012S
Line: BTF
* 1 Year Limited Warranty
* 5-9 PSI
* 30GPH
* Universal Product
41.99 plus tax
PostPosted: Sat Sep 04, 2010 6:25 pm
my previous post is wrong. don't use that pump the fuel pressure is to high.
http://www.oreillyauto.com/site/c/detai ... rd=be8016s
# Universal
# Type: Solenoid
# Volts: 12
# Pressure: 2.5-4.5 PSI
# Flow (GPH): 30
# Inlet/Outlet Size: 5/16" Hose
51.99
i either have to change my pump again or put a fuel pressure regulator on mine now cause the pump is pushing past what the float needle can stop
PostPosted: Sun Sep 05, 2010 7:58 am
Thank you for the update Jeramy. I think I've narrowed down the problem to the fuel pump giving up the ghost. But I've decided to rebuild the fuel system from front to back anyway. So a new fuel pump is in order. viewtopic.php?f=5&t=23357
James Bates
