It is currently Sun Jun 28, 2026 5:38 am
Post new topic Reply to topic  [ 294 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 15  Next
PostPosted: Fri Aug 31, 2007 7:54 pm
installed
PostPosted: Fri Aug 31, 2007 8:24 pm
that interior is kick a$$ :D what did you use for the dash? cuz me like it lotz
PostPosted: Fri Aug 31, 2007 8:56 pm
the interior is all black tweed besides the green tweed inserts in the seats
PostPosted: Fri Aug 31, 2007 9:10 pm
did you have like a good dash pad or did you make it
i wanna c if any ones made one or can i buy one some where?
PostPosted: Fri Aug 31, 2007 9:14 pm
Dash pad was trashed so I tore it out. So I foamed the top of the dash and tweeded over the foam and steel.
There is a place to get a replacement dash, it has topics somewhere in the forum. They are only made in Australia and run a pretty good chunk of change.
PostPosted: Fri Aug 31, 2007 9:18 pm
sounds better than payn for one so what kinda foam did u use or is it a secrete cuz im sure it could help alot of us out :D
PostPosted: Fri Aug 31, 2007 11:07 pm
I buy foam from http://www.yourautotrim.com
 Post subject: look n good
PostPosted: Wed Sep 12, 2007 2:29 am
well i luv what you have done wit ur loooooooog luv so i am going to get started on mine so i can take it to the show that the club i am in is having danger zone april 5 you all need to come
http://www.myspace.com/DANGEROUSTOYSORG OR
I HOPE YOU WILL TELL A FRIEND IT IS ONE OF THE BIGEST SHOWS LAST YEAR THERE WAS NOT ONE LUV THERE
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Mon Oct 15, 2007 10:35 am
hey man, great work...very nice!!!!! :D
PostPosted: Mon Dec 17, 2007 8:35 pm
Well time to bring the thread back to life! I started back on the luv last weekend. Tonight I just shaved the "Chevrolet" outta the tailgate so the ass end will be completely smooth. Well here is the To-Do list by Spring so be ready for updates:
- Stock floor body drop(frame painted green)
- New rear setup
- Sheet metal bed
- Suicide drivers door
- Engine/Trans overhauled
- Shaved Firewall
- Trailer Fenders in front
- A little bodywork
- Maybe a turbo? Not sure yet
PostPosted: Sun Jan 13, 2008 9:28 pm
Got the cab/bed off the frame to get ready for the stock floor body drop :smt003 Also I started makin some fiberglass door panels, they're turnin out awesome :smt045
PostPosted: Mon Jan 14, 2008 9:59 pm
holy 4 link batman!!
8O
PostPosted: Tue Jan 15, 2008 11:33 pm
It's from suicidedoors.com, in my opinion the beefer the better
PostPosted: Mon Jan 21, 2008 8:41 pm
Gotta update, all cross members are out, my buddy is helping me w/the sfbd and made the transmission mount, is removable just in case somethin needs worked on. The U's in the cross member are for the dual exhaust to go through, and its hangin low because the frame hasn't been Z'd and doesn't have the bottom steel tubin. Got the engine and transmission out also, took the engine today to the engine shop to get all re-done, and after we mock up for the drive shaft hump/4link cross member the transmission will also be sent out to get re-done. Just ordered tubin for the frame, and some misc. stuff, updates will be comin
PostPosted: Tue Jan 22, 2008 2:27 am
8O
PostPosted: Tue Jan 22, 2008 8:09 pm
Very Very very Kick A**, That truck is going to hit the cover of MiniTruckin for sure.... 8)
PostPosted: Sun Jan 27, 2008 9:29 pm
The total body drop is gonna be 3 1/4" to the pinch. Here's some progress from this weekend. Got the driveshaft/4-link crossmember made and mounted, redid the axle/notch brackets, changed the upper 4-link angles, welded on the tubin on the bottom of the frame, cut off body mounts and lowered the rear mounts.
Next weekend will be cuttin the stock frame from behind the cab to the Z, like the picture shows below, then weldin flat strap on the top. Then mountin the cab back on line up the front mounts and mark where they will be on the frame, tack them in place, set the body back down on the pinch :D
PostPosted: Sun Jan 27, 2008 10:44 pm
looks good but the bars at the new cross member is not the same on the rearend the inside is up and the outside is down so the part at the new cross member needs to be inside down and out side up so they are the same but opposite i hope you see what i mean sometimes it is hard when you have been staring at it for to long :lol:
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Sun Jan 27, 2008 11:10 pm
I kno what you are sayin but everything works fine, the bars are the same length, they have adjustable ends, so the slightly different angles on the rear end are equaled out after adjustment, believe me, my buddy knows suspensions, here is a pic of his custom canti-lever on his 78 c10
PostPosted: Sat Feb 09, 2008 10:13 pm
Didn't work last week on the Luv, other stuff came up, so today we did the Z, cut the rest of the frame off and plated it, put the new tabs on the 4-link, and cut the front of the core support off. Tomorrow cab will be on for fitment for front body mounts, should have pics tomorrow layin pinch
Users browsing this forum: No registered users and 69 guests
