It is currently Mon Jun 08, 2026 2:11 pm
 Post subject: Sway Bay Bushings (kit?)
PostPosted: Fri Aug 01, 2008 12:00 am
I need to replace the bushings on my swaybar on my 80 4x4.
I saw on US Auto Parts, there is a kit for the 2WD, but I wasn't sure if that would work
on the 4wd. That site doesnt' have the option to choose 4WD while doing a vehicle search.
If anyone knows please post a link and brand/part #
Thanks! 8)
PostPosted: Fri Aug 01, 2008 2:15 pm
I asked the local parts guy about that same thing....he said bring what you need in and we can find ya something close if nothing else.
PostPosted: Sat Sep 13, 2008 1:45 pm
When I first got my 4x4 Luv, the bushings on the sway bar were very deteriorate.
I don't remember what type of busing I bought, but they weren't for a sway bar. The dont seem to mount right. The upper mount has a big gap between the bar and the stud. The lower mount compress the rubber down and I'm wonder if that effects how it functions.
I'm going to post the pics of mine. I'm wondering if anyone that has the stock bushing can post pics of the upper mount and lower mount of their sway bar.
Upper mount:
Lower mount:
Upper mount to frame:
PostPosted: Sat Sep 13, 2008 4:03 pm
Australian LUV Guru
This pic may help, just blow it up a little.
Your Luv looks to be missing a few washers.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Sun Sep 14, 2008 10:49 pm
I was searching Napa website and found this:
Stabilizer Linkage - Front Suspension
Part# RPC 15999
Could this be the right parts?
http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=430&Keyword=sway%20bar&KeywordCat=Sway+Bar+Repair+Kit+-+Front+Susp&VehCode=Y
PostPosted: Mon Sep 22, 2008 7:08 pm
I just got the Stabilzer kit (Sway Bar bushings)today. It's made by RareParts. I've heard of them before. The kit includes 2 bolts with casing (see picture), 2 nuts, 8 flat washers, and 8 rubber bushings. The bolt seems to be really long compared to either the lower or upper mount on the Stablizer bar.
PostPosted: Tue Sep 23, 2008 11:44 am
I took mine off cuz of the noise it was making it dose not ride any diffrent
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Wed Sep 24, 2008 8:50 am
Well no, not untill your on the freeway and make a sudden swerve to miss an AZ aligator (blown out tire carcuss). Then it might roll over like a Suzuki Samari.
PostPosted: Wed Sep 24, 2008 8:58 pm
But it will be a QUIET wreck! :roll:
PostPosted: Wed Sep 24, 2008 11:24 pm
:P
PostPosted: Fri Nov 07, 2008 7:37 pm
I'm putting my Sway bar back on my Luv tomorrow. I was looking at the diagram that OzluvTrucker posted (also in Luv manual). If you look at the lower arm of the sway bar (see part number 12), just below the eyelet of the bar looks like another rubber bushing, but that part is not labeled. Can anyone take a look at your 4x4 Luv and let me know?
Thanks!
PostPosted: Sat Nov 08, 2008 3:50 am
Australian LUV Guru
The kit you bought is a multifit for 2wd, all is not lost though. You can use some the rubber bushes and washers on your 4x4. Take a look at the pics below and assemble yours the same.
PostPosted: Sat Nov 08, 2008 9:45 am
Thanks for posting that pic Oz! That's how mine looked before I took it apart.The previous owner had put others thing together incorrectly. :roll: Thought I'd check first. =)
PostPosted: Sat Nov 08, 2008 3:44 pm
Ok, So I'm about to put the sway bar on, however I notice the top mount doesn't look like there is a enough length to have 2 bushings, washers, and go through the front plate on the chasis.
OzLuvTrucker posted a pic from underneath the front chasis, and I see two washers and a bushing, but on the top of the plate is there another bushing? Again the diagram shows theres 2 bushing on the top mount of the sway bar. See my 2 pics
PostPosted: Mon Nov 10, 2008 3:08 pm
Well I used the same setup as OzLuvTrucker (from his picture) with the upper mount.
I went washer, bushing, washer, then on top of the plate I just used a nut and lock washer.
If anyone setup is diffrent, please let me know.
Thanks!
