It is currently Tue Jun 30, 2026 10:53 am
 Post subject: CARB ?
PostPosted: Sat Jun 16, 2007 3:20 pm
my truck was runnin fine and now it won't idle. It will run pating the gas but runs real ruff. my resistor ontop of the coil gets hot when the key is on. Is this normal? I'm trying 2 check the solinoid on the carb 2 see if its gettin fire when the key is on but I dont no where it is. There are 3 different things that look posible 2 be the solinoid 2 me. This is in a hatichi carb
PostPosted: Sat Jun 16, 2007 5:06 pm
Mike
Try to adjust the idle screw clockwise just a bit, barring electrcal, that may help idle.
FIAA: Color Guard
PostPosted: Sun Jun 17, 2007 4:08 pm
yeah that resistor will get hot normaly. check your point gap, spark, fuel and whatnot.
