It is currently Fri Mar 13, 2026 6:59 pm
 Post subject: 79 4x4 Trans Rebuild
PostPosted: Fri Apr 24, 2020 1:34 pm
Hey y'all. Looking for some insight on my trans rebuild. I recently took my trans to a reputable trans shop in the area, everyone told me that they can rebuild anything, and at first they were like " yea, sure, bring it on by". But, after all, they said they couldn't do anything with it due to unavailability of parts. To me that means that if that were true nobody would be able to rebuild it for me. I've looked for rebuild kits and couldn't find anything either. Has anyone here rebuilt there 4x4 4 speed trans, or had someone else do it? Are there parts available somewhere? I also need the shifter bushings circled in the attached pic. Any help on this is much appreciated. Thanks for reading.
 Post subject: Re: 79 4x4 Trans Rebuild
PostPosted: Mon Apr 27, 2020 5:06 am
Not gonna be from any US sources... There may be some kits available on the asian market or MAYBE australia. If you can find someone who can navigate those sites.
PostPosted: Thu Apr 30, 2020 5:04 pm
That's not good news for me. Mine needs a rear bearing and I was going to have my spare rebuilt and just swap it out. :(
PostPosted: Sat May 02, 2020 8:19 pm
Get measurements on the bearing and see if you can find a suitable replacement off size
PostPosted: Tue Jul 14, 2020 7:53 pm
Good thread. I have the Trooper 5 speed in my LUV, but it does have a noisy bearing while in 5th gear.
Are the parts hard to find as well for the Trooper transmission?
PostPosted: Wed Jul 15, 2020 5:44 am
Which Trooper transmission do you have?
PostPosted: Mon Aug 03, 2020 5:35 pm
I got the Trooper off this unit:
I think it was an 84 or 85 Trooper.
2.3 Liter
Engine Family:
Gsz138t2dgx
PostPosted: Mon Aug 03, 2020 6:13 pm
I run an '89 Impulse transmission in my P'up. When I got the transmission, it had one bearing that felt gritty when I turned it. My transmission shop was able to match it up to some Timken or other readily available bearing. Exactly as luv4theluv said.
2.3 Liter
Engine Family:
Gsz138t2dgx
For what it's worth, if it's a 5-speed, it had to have come from an '86 or '87. Any 4wd before '86 was 4-speed. it should be an MSG5T.
PostPosted: Mon Aug 03, 2020 7:06 pm
I have a spare 4x4 transmission. I'll just have it rebuilt/gone through and R&R it. Hopefully whatever parts are needed will be available.
PostPosted: Tue Aug 18, 2020 12:24 am
I 'll have to talk to a shop, but I think there's a good chance they could find the parts needed.
PostPosted: Tue Aug 18, 2020 4:47 am
I've been recommended a shop near me, but have not called yet.
