It is currently Tue Jun 16, 2026 4:06 am
PostPosted: Sun Mar 11, 2007 1:00 am
Hi y'all
Thought I'd come have a look around on here - see what info I might find. I own 2x Holden Rodeos - same as US spec Isuzu P'up - an '89 Spacecab with 4ZE1 & an '88 Std Cab trayback with 4ZE1 + HKS 2540 Turbo. Best ET for the Spacecab 16.4 sec 1/4, & 14.4 for the Turbo.
PostPosted: Sun Mar 11, 2007 9:17 am
G'day mate...
PostPosted: Sun Mar 11, 2007 11:06 am
Welcome and you don't see many of the spacecab like your white one around much. Yours looks good
Have you finished the SR20-DET Conversion into TF yet… and how does that run compared to stock, also doesn’t that motor have a stand alone brain that goes to the motor only ( easy to wire) or not
PostPosted: Sun Mar 11, 2007 3:37 pm
Looks like th eimage links died...
Is this the right place? If so, sweet ride!
http://www.isuzupup.com/gallery/v/tfr-t ... U.jpg.html
:D
1978 shortbed fleetside, th350, Fireball 231 Even Fire V6, Edelbrock 500CFM Performer with Edelbrock intake. Workin' Truck.
PostPosted: Mon Mar 12, 2007 2:52 am
Yeah, the conversion is done - it's in the hands of the tuners ATM, but hopefully will be testing this Saturday & will keep you posted.
Running the electronics was quite easy actually. As we had a Silvia front cut to work with it was just a case of pulling the computer & loom to go with the motor. Only had to ensure the power was supplied to the right connections & away it went.
