 Post subject: Transmission?
PostPosted: Wed Oct 05, 2005 10:14 pm
I just got a 1982 Luv Diesel with a 5 speed manual. After about 200 miles while driving down the freeway at about 65 it went bang and started slowing down. I down shifted to 4th and made it the 4 miles to the exit where I had to stop. After that it wouldn't move at all. Any suggestions where to start?
Thanks
PostPosted: Thu Oct 06, 2005 12:18 am
injector timing and valves is where i would start.
PostPosted: Thu Oct 06, 2005 7:15 pm
The engine runs but I have no gears.
Greg
PostPosted: Thu Oct 06, 2005 7:28 pm
snapped input shaft, mainshaft, blew the clutch disk???
PostPosted: Thu Oct 06, 2005 8:13 pm
Possibly a transmission bearing failure...which may have caused other disasters. I believe these transmissions were subject to bearings giving out.
It sounds similar to what I had happen to a 1976 Celica I had once.
Was the transmission quieter in 4th gear? I ask this because 4th is a direct gear (I think) and doesn't use the secondary shaft in the tranny, on which a bearing may have failed. There are others on here that certainly have experience with these transmissions.
Bona Fide diesel fanatic.
Kubota B6100 HST diesel
PostPosted: Thu Oct 06, 2005 10:20 pm
The truck wouldn't drive in 5th, after the bang it started slipping. I put it in 4th and it went till I came to a stop sign where once stopped I couldn't get any gear so I towed it home. Tomorrow I'll get it off the trailer and see what I have.
Thanks
