PostPosted: Fri Jun 17, 2005 6:21 am
Hi all. The front main on my 81 Luv is bad, and I'm going through a quart of oil every week (~150 miles). As long as I have to pull the motor, I may as well replace all the gaskets and seals. I'll check compression before I tear it apart, but it may snowball into a ring and head job, in which case I may as well do a complete overhaul (250k miles.). All because of a $2 main seal...
I'm just starting to do my research, but I have found a gasket set for a later C223 engine. Does anyone know if the internals, water jackets, etc. of the later diesels (say 1984-85) are similar enough to the earlier ones ('81) that the gasket set is interchangable?
Also, what sort of mileage do people see out of 4x4 diesels. I'm seeing 30MPG, but I read on an earlier post that people see 38-45. Maybe those are 2 wheel drives, or it may be another indication of wear in my engine.
Thanks.
PostPosted: Sun Jun 19, 2005 12:02 am
Are you sure you don't just want to replace the seal and leave everything else alone? I've heard those diesels are built like tanks.
-DK
 Post subject: That Depends
PostPosted: Mon Jun 20, 2005 8:05 am
If I can replace the seal without removing the crank, (With a press-on seal like transmission splines use.) then yes. If the seal is like SB Chevys, where I have to pull the crank, then I might as well do everything at once.
Any information?
PostPosted: Mon Jun 20, 2005 11:57 am
The 2.2 diesel are built like tanks... :twisted:
I have done a head job on mine and the parts are very costly...
Here is something..when searching for parts you can also ask for parts to 82-87 isuzu pup diesels....they have the same motor and most parts store will list the same exact part cheaper under the isuzu pup as opposed to a luv...its kinda weird....
A head kit for my truck listed under a 81 luv...was almost 350 dollars.....
Looked for the same kit under a 82 isuzu pup and got the same kit and same part numbers for 150.00.....its weird
My luv currently gets about 42 mpg last time a checked.....
PostPosted: Tue Jun 21, 2005 9:35 am
Thanks Slick. Is that 42MPG a 4x4?
PostPosted: Tue Jun 21, 2005 8:56 pm
Yes 42mpg.. its great especially with prices of gas
:twisted:
PostPosted: Mon Nov 28, 2005 3:12 pm
really, over 40 mpg with a 4wd? that's unheard of from my experience
I cant even crack 30 with my 82 4x4, even with 15" tires.
