It is currently Sat Jun 13, 2026 8:44 am
 Post subject: advice
PostPosted: Thu Jan 10, 2008 7:32 pm
first the problem,i'm using a set of 461 double humps, and i keep running into problems with these heads, i have harland sharp roller rockers and they rub on the casting for the rocker studs so i tried a cheap fix i got stock replacement roller tips,solved that problem now i'm getting coil bind on the valve springs, i was told i need atleast 80 thousandths between coils when cam is at full lift and i only have about 26,so should i have the 461s machined to work or should i just buy a set of heads ? i know i should probably buy heads but it helps to hear someone elses opinion. now what kind of heads should i buy? the 461s are 64 cc which makes my motor about 13:1 i don't mind buying race fuel and it is ready available but should i go to bigger cc,what size intake runners should i get what about valve size my cam is 545/565 solid lift what are the +s and -s to larger cc heads any help would be great :smt021
junkyard racing - we win with your old parts
PostPosted: Fri Jan 11, 2008 1:00 am
What is the rest of the combo? Pm me if you don't want everyone to know. It's hard to recommend something without knowing the specs.
PostPosted: Fri Jan 11, 2008 3:38 am
pm sent , oh ya did i mention when my truck grows up it wants to be like yours mytmouz :D
PostPosted: Fri Jan 11, 2008 8:48 pm
If you need to get the spring pockets machined and the stud bosses you might be better with a new set of heads. like the world products sportsmans. they are a preety decent head have accessory bolt holes. I think you can get them in 64 or 76 cc chambers. there are several good iron and alluminum heads out there now.
PostPosted: Fri Jan 11, 2008 11:56 pm
i think i have decided to go with dart platinum :D :D
