It is currently Wed Mar 18, 2026 8:52 am
 Post subject: Hi all Have a ?
PostPosted: Sun Jan 21, 2007 3:59 pm
this head goes on,it was left at are house some time a go and the guy never came and got it, We know it was from a Isuzu PU 2wd but didn't know the engine size, I have Pics, so take a look see what you think it is
Thanks Angie
 Post subject: Oops
PostPosted: Sun Jan 21, 2007 4:04 pm
top got cut off
here it is again :oops:
Was wanting to know if any one could help me identify what size engine this head goes on,it was left at are house some time a go and the guy never came and got it, We know it was from a Isuzu PU 2wd but didn't know the engine size, I have Pics, so take a look see what you think it is
Thanks Angie
PostPosted: Mon Jan 22, 2007 12:29 am
Looks like a head off of a later model isuzu 4 cylinder with a timing belt.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Mon Jan 22, 2007 1:31 am
Swap Specialist Mod
i dont think its an isuzu head. the intake and exhaust ports arent spaced right and theres no hole in the intake side for the distributor. that and a 4Z head would have a "4ZD1" or whatever tag cast into it to identify what its from.
PostPosted: Mon Jan 22, 2007 1:50 am
I thought that on some of the isuzu engines the distributor came straight out of the back too? :?
1975 V8 Luv
1980 Bagged Luv
PostPosted: Mon Jan 22, 2007 1:52 am
Swap Specialist Mod
well i got to thinkin and this might be a 4X head. from like a early geo storm. they have the same design as that head.
PostPosted: Mon Jan 22, 2007 11:08 am
The head has "jet valves" looks Mitsubishi to me.
PostPosted: Mon Jan 22, 2007 1:26 pm
heres are 2 more Pics , it looks like the Distributor hole is near the timing gear :o
PostPosted: Mon Jan 22, 2007 4:50 pm
PITA Old Fart
It kinda looks like the Luv style head a bit...how do you know it came from a Luv engine?
It has the air injector holes...and the exhaust and intake ports look similar...but it's been a while since I tore one apart...so what the hell do I know?
I couldn't tell you what I had for breakfast...I suffer from C.R.S pretty bad....lol
PostPosted: Sat Jan 27, 2007 12:55 pm
Thanks every one for all the input on this. I think Luver8 gave us the answer, after he said Mitsubishi hubby remembered thats what it was from thanks so much
Angie :D
 Post subject: Head
PostPosted: Sat Jan 27, 2007 7:28 pm
I think that head is for a mitsubishi 2.6 eng out of an early 80 Dodge caravan etc, or the dodge ram 50, or the little mitsubishi mighty max pickup, same as dodge ram 50. The fwd, and rwd engines were different, external design and would not inter-change.
Diesels, 86 Isuzu 4x4, 2 87 Long bed 2 wd, 85 2 wd turbo-d long bed, 84 l bed [utility], 85 2 wd long bed, 1 86 swb 2.3 gasser
PostPosted: Sun Jan 28, 2007 2:00 am
Angie :D
Don't mess with me and Mitsubishi's they are my favorite cars and trucks and I have plenty Mitsu's to prove it. I have a 95 Mighty Max, 02 Diamante, 04 Gallant and a 06 Lancer. I am also a ex Mitsu master mechanic, I worked at a dealer here in So Cal for several years.
