It is currently Tue May 26, 2026 12:05 am
 Post subject: Chevy Vega platform
PostPosted: Thu Nov 09, 2006 7:28 pm
I was scrounging thru the local junkyards today and i found a replacement radiator core support for my LUV. They'll have it cut out for me by Saturday. I also found a Chevy Vega hatchback that looked pretty good body-wise. I heard that these cars will rust away overnight. Is this true? I'm tempted to concider this as a platform for a 1/4 mile only machine. Mount kits are all over the Internet so this is a positive aspect. But if the bodies have a tendency to crumble away, i will drop the idea.
Anyone got some insight of the Vega?
PostPosted: Fri Nov 10, 2006 3:43 am
I'll take a stab at this post, knowing I'm risking getting hammered from the vega lovers. A vega makes a great race car in stock bodied form until around the 9.9 1/4 mile mark. The car has a tendency to wander on the top end of the track due to air getting under the car and lifting the front. My buddies and I have had several and the tendency was the same for all. Chassis work, spoilers and air dams will all help. Monzas tend to work better when the et's get lower. Again this is from our personal experience. Again, I don't want to offend any one with a vega, because I'd have another one in a heartbeat. I'm just trying to help someone out.
PostPosted: Fri Nov 10, 2006 4:35 am
I Too Have Heard That About The Thousand Foot Mark The Nose Tends To...Float. My Uncle Has One Here In Town. He Solved This Problem By First Basically Slamming It. Then Using A Front Air Down. He Is Currently Running a Merlin 632 W/ Big Chief Heads. And You Can Ask RedLuv80 It Sounds Pretty With Zoomies. His Only Prob Now Is Hooking Even Though He Has Tubed The Living Bajessuses Out Of It and Four Linked It. I Believe Its The Tire Compound He Is Running Believe There Are Call M/T Indy's or Something I Told Him He Needs To Run A Straight Slick or Drag Radials. But Enough Of My Rambling.
My Opinion is... Well Due To Late "Jungle Jim" Liberman
I Would Have To Say...... I Love The Little Bastards...lol But I Have Heard There Temperamental. I Specially Love The Oder Models 70-73 The Ones Nicked Named The Mini Camaro's "least around here"
Aerodynamics, Rust, and Hooking Are There Only Probs From What I Have Gathered.
PostPosted: Fri Nov 10, 2006 4:53 am
We ran a big block in one to get the nose down. Then we added an air dam. This made it light in the rear. Adding a wing out back to create downforce helped a lot.
PostPosted: Fri Nov 10, 2006 5:26 am
That May Be The Deal Then...It Hooked Up Fine W/ A Built 383 But The 632 Is Giving Him Problem Hooking......Can't Transfer All The Weight Properly and Breaking Lose? or Maybe Just The Added Power?..or He Might Need A Wing.. This Guy Is In His Late 40's and Drives This Car Almost Daily...W/ The 383 It Was Literally His Grocery Getter. Ain't He Living A American Dream...lol
PostPosted: Sat Nov 11, 2006 1:49 pm
If you can swing a deal on it I would it`s just like another luv project except you can put your friends in the back seat. but yeah your right headers mounts etc are all over the place
PostPosted: Fri Nov 24, 2006 12:20 am
Typical Chevy Rust problems from that era. Front cowel, front window, rear window, rockers etc. Sort of a luv truck project. It can be made to run true and straight.
A lot of short wheel base cars do not run at the drags anymore. they can be very unstable. But a blast to watch. Lots of vegas still out their, just getting harder to find good cars that are not rust buckets. Go for it, if you found one. 70-73 look like a baby Camaro
PostPosted: Mon Nov 27, 2006 8:19 pm
I drove a few years ago on slick/rough tracks they were a hand full.Same lift problems as most pony cars.Makes a cheap fun fast car .
PostPosted: Mon Nov 27, 2006 11:08 pm
why dont ya come pick mine up. its a blast to launch with the 4.88's lol!!! the top end is easy to handle, its the launch that gets a little squirly sometimes. :lol: and it doesnt have any rust on it.
AINT RIGHT MOTORSPORTS
PostPosted: Tue Nov 28, 2006 12:13 am
Where in Texas are you and how much will to sell it for?
